Old 05-15-2021, 02:35 PM   #1
Water pressure issues
Hello all, long time reader. I have a 2005 31 Classic. We took it out last night to get the kinks out before our big family trip. Unfortunately there was an issue. There is little to no pressure in the shower (I checked and rechecked the valve on the shower handle) and the pressure to the hot water in the kitchen sink is non existent. The bathroom sink has no issues at all. There are no leaks that I can see. Any thoughts on the issue? Thank you for the help.
jtbentley is offline   Reply With Quote
Old 05-15-2021, 02:42 PM   #2
Dennis C's Avatar
Evergreen , Colorado
It could be a clogged mixing valve on your hot water heater. If so, this is a pretty easy repair.
Do you have cold water pressure? Does you hot water get warm and then turn cold?
You might also check your valves to make sure that your hot water heater bypass valve is in the correct position.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
Dennis C is offline   Reply With Quote
Old 05-16-2021, 07:46 PM   #3
Dennis
Thank you for your response. I am hoping this is an easy fix. I am trying to find the mixing valve on my water heater, but am unsuccessful at this point. Just need to keep digging and looking through the manual.
Water pressure regulator used to regulate air pressure? Atsushi Winterizing, Storage, Carports & Covers 8 10-26-2018 08:16 AM
Does on-board water pressure regulator protect against excessive air pressure? Hermes Winterizing, Storage, Carports & Covers 2 10-07-2018 03:25 PM
Water Pressure Issues davedream208 General Repair Forum 0 09-30-2017 05:01 PM
Water pressure issues airsovereign Plumbing - Systems & Fixtures 1 03-05-2017 08:40 PM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 04:22 PM
