RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 01-25-2021, 03:38 PM   #1
PLANO , TX
water leaking.
My AS is 1992 29' Excella mid bath. Once I connected city water, it started leaking and floor is wet. However, I don't see any leaking along the water pipe. Leaking must come from somewhere else. Can someone help me to find out what could be the source of the leaking? Anyone has the plumbing diagram of 1992 Excella?
ID:	387554   Click image for larger version
Xin Li is offline   Reply With Quote
Old 01-25-2021, 04:19 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
You may want to download this 1992 Owner's Manual or other 1992 Documents...they may help you troubleshoot this problem. Good luck!
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-25-2021, 06:17 PM   #3
2016 23' International
Long Beach , California
Check out your city water inlet while the pipes are pressurized.
The shurflo city inlet with pressure regulator is notorious for leaking.
Seanlb is offline   Reply With Quote
Old 01-26-2021, 05:42 AM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Old Timer restoration members,
Is that the Polybutylene pipe?
https://www.polybutylene.com/poly.html
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Water Leaking at Wheel Well when water is hooked up Lauren25 Plumbing - Systems & Fixtures 18 12-28-2017 09:34 PM
Help! Water Leaking into my Fresh Water Tank dasams Fresh Water Systems 15 06-21-2017 09:57 PM
Water leaking from fresh water input 3dawgnight Plumbing - Systems & Fixtures 2 10-25-2016 12:01 AM
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 12:38 PM
Water leaking when connecting city water- mystery hose nozzle Romelio Fresh Water Systems 1 11-16-2015 07:01 PM
