02-25-2019, 05:13 PM
2018 26' Flying Cloud
Murrieta
Water leak?
Hi guys, took out the 2018 for it's 1st shakedown trip last week and when I got home and dumped the grey water tank noticed a slight drip coming from underneath the belly pan by the valve. Is this considered "normal"? I have an appt with Airstream next week to drop it off and have them do a slight floor repair that was mentioned at PDI. Any input would be appreciated.
02-26-2019, 08:17 AM
I'm In
, Kentucky
Hard to tell from the picture. Could it be condensation from something? Have you crawled underneath to see what's above it? Is it just coming from the belly pan?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
02-26-2019, 04:01 PM
Murrieta
It's coming from the corner of the pan after I flushed the grey tank. Not condensation. The larger wet spot to the left is nothing. I had rinsed off the trailer of some dirt and was from that.
02-26-2019, 04:14 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
The tank enclosure should not have a drip, unless you towed through rain. Both the gray and black tank are inside that metal enclosure (that enclosure is not the belly pan)
If you took warm showers during cold weather that could create condensation inside the enclosure, then it is possible for it to accumulate inside the tank enclosure which could drip.
If there has been no rain or conditions creating condensation, then something inside the tank enclosure is leaking.
To test, fill both tanks with water. If there is no recurrence of the drip, then there is no problem
Alan
02-26-2019, 04:54 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Flushed gray tank? If you ment flush black tank with the tank flush system you could have a leak in the flush system. Not uncommon. There is a screw on connection inside the trailer that can loosen. Hand tighten it if loose and you are good to go.
02-26-2019, 06:12 PM
Murrieta
Do you happen to know where this screw on connection is located? We have a 26 RBQ flying cloud.
02-26-2019, 06:16 PM
Overkill Specialist
Dadeville
, Alabama
It will be inside the trailer just behind where the flush is on the outside. Looks like on your 26FC it would be Streetside closet area.
02-26-2019, 06:18 PM
1995 25' Excella
xxxxx
, xxxxxx
Put different colored food coloring colored water in the black and gray tanks and see if the water dripping matches.
02-26-2019, 06:28 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
The black flush system has a vacuum breaker just inside the trailer from the exterior hose connection, these are notorious leakers and the one in our 2011 Bambi was no exception.
it spewed water in the cavity behind the lav sink where its located and would eventualy run down under the trailer.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
02-26-2019, 06:30 PM
1991 25' Excella
Santa Ynez
Good idea!
Will Rogers
Alan
02-26-2019, 07:29 PM
1995 25' Excella
xxxxx
, xxxxxx
That is how I determined both of my holding tanks were leaking at the valve to tank adapters.
