Old 04-11-2021, 12:05 PM   #1
2005 30' Classic
Hillier Prince Edward , ON
Water Heater Problem
Hello Everyone,
I just got back to Canada where I had my 2005 30í Classic stored for the winter.
It was winterized by a professional. However, when I hooked up the water and turned on the pump, I let the water get up to pressure and ran both hot and cold water. I then flipped the switch and heard the gas water heater ignite and thought everything was OK. However a few minutes later I heard some noise coming from the water heater, opened up the outside cover and the burner was on but it was making a lot of racket. I shut it off and now the burner comes back on but shuts off quickly. Any ideas of what might have happened and how I fix it?
Thanks for your help.
Robert
Robert1944 is offline   Reply With Quote
Old 04-11-2021, 12:15 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Is the water heater bypassed? Make sure the valves allow water to flow through the heater tank.
Richard
azflycaster is online now   Reply With Quote
Old 04-11-2021, 12:36 PM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Any evidence of soot at the burner or exhaust louvers?
Does it sound like a lawn mower that has a bad miss? Pop poof Pop poof etc?
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
Old 04-11-2021, 01:51 PM   #4
2019 30' International
Pennsylvania , Pennsylvania
Watch this, maybe it'll help.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 04-12-2021, 04:42 PM   #5
2005 30' Classic
Water Heater
Thanks everybody. I found out that I had not opened one of the valves for water.
What a relief!
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Water Heater Problem Cracker Water Heaters, Filters & Pumps 3 06-11-2004 07:42 AM
Bowen water heater problem, anyone know what to look at? Silverfly Water Heaters, Filters & Pumps 4 05-04-2004 10:56 AM
water heater problem Stefrobrts Water Heaters, Filters & Pumps 4 10-23-2003 08:55 AM
