Old 05-06-2020, 08:22 AM   #1
2016 27' International
Wadsworth , OH
Water Heater
I saw a few threads but most left we still questioning my problem. First time really using my 2016 Airstream. Water heater runs on either electric or gas. Been running electric, lights just fine. Light flickers! But occassionally after it remains on the light becomes solid red. If I turn off and on it goes away, granted may reappear 5-10 hours later. Any thoughts? Do you leave your water heater on all the time or only before you use it?
bpsakowicz is offline   Reply With Quote
Old 05-06-2020, 08:31 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
We only run the WH a couple of hours a day. Once in the morning and again in the evening. Can run it all the time but do not.
On our old model the red light is a fault light for running it on gas. I am confused buy what you said. Running on electric it should not "light every time". That makes it sounds like you are running it on gas. If so, then the red light indicates that it went out. Maybe you have both gas and electric on at the same time?
Old 05-06-2020, 10:13 AM   #3
Wadsworth , OH
Thanks Bill. Yes, it does have the option on utilizing either but the gas has been off. Propane tanks are closed and switch is off.
Old 05-06-2020, 10:38 AM   #4
Long Island , New York
Welcome to the forum!
What does your owner's manual say?
The answer can vary for different years/models, so the manual is the best place to start. Your Airstream briefcase should also contain a mfg. pamphlet for the heater.
You might want to check in the water heater forum:
https://www.airforums.com/forums/f445/
Good luck,
Peter
Old 05-06-2020, 10:45 AM   #5
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
When my wh had the original control board a red light meant a fault. After I replaced my board with a Dragon board, the red light means a fault in the gas mode, but the red light is normally one when the water heater is in the electric mode. Just a data point for you.
Larry
lsbrodsky is offline   Reply With Quote
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
