Old 06-29-2020, 07:54 PM   #1
2006 25' Safari SS SE
Elk Grove , California
Water drip from rubber nipple/nub near tank flush
Hi all, not sure what the purpose is for this nub but I see water dripping from it. The only thing Iíve done recently that might be related was replaced the cartridge in the Moen shower faucet. Could it be related? Itís near the grey tank pull lever.
thegarse is offline   Reply With Quote
Old 06-29-2020, 07:57 PM   #2
2016 25' Flying Cloud
z , Texas
That's your led light, I believe, water should not be dripping from it
5150mike is offline   Reply With Quote
Old 06-29-2020, 08:40 PM   #3
rd tighe's Avatar
2007 25' International CCD FB
We are , Relaxed
Images: 12
You probably have a leak above it. Time for a little detective work and yes it is a light.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' FB International CCD Solar
2019 Toyota Tundra
rd tighe is offline   Reply With Quote
Old 06-29-2020, 09:09 PM   #4
I feel dumb, and I bet the other smaller nub must be the switch. How on earth do you get to the plumbing for the shower faucet? Btw this is a 2006 Safari 25í. I did all the cartridge work from inside the shower and having been there I can tell you you cannot get to anything other than the cartridge from the inside.
Old 06-29-2020, 09:22 PM   #5
z , Texas
https://youtu.be/_akSh-a1Chw
Does this help
Old 06-29-2020, 10:02 PM   #6
That’s actually the video I used to help me with the inside part of the job. That it attaches to between the bath fiberglass and the outer aluminum is what I’d like to know more about.
Old 06-29-2020, 10:50 PM   #7
aftermath's Avatar
Spokane , Washington
Mine has an access door in the closet.
aftermath is offline   Reply With Quote
Old 07-01-2020, 01:09 PM   #8
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
This is really going going to sound ridiculous. When I had the Airstream Service Center replace my rear A/C cracked drain pan the tech could not find the drain tube. It is supposed to exit at the rear inside surface of the roadside wheel well liner. Guess where I had a leak? In the same place as yours. Correctly placing the drain tube cured the leak. That had been there since production.
guskmg
Drip, drip, drip. Or not to drip? Vitaver Plumbing - Systems & Fixtures 9 12-19-2016 07:25 PM
drip- drip-drip-drip-drip.... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 3 08-09-2009 07:32 AM
Arrggggg! Drip, Drip, DripóWarning, plumbing questions Jim & Susan Sinks, Showers & Toilets 16 06-10-2009 08:04 PM
Drip, Drip, Drip kamadeca Fresh Water Systems 4 05-20-2008 08:22 PM
AC drip,drip,drip,drip,drip Canuks Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-02-2006 02:05 PM
