Old 07-04-2022, 05:06 PM   #21
New Richmond , Wisconsin
Great. Thanks!!!
KellyMeer is offline   Reply With Quote
Old 07-04-2022, 09:05 PM   #22
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Backing up a bit ....
When you bought the trailer, was there a walk through after you did the paperwork? If so, what did they go over with you?
Old 07-04-2022, 10:39 PM   #23
Bearstream01's Avatar
Garden City , New York
Just FYI because Im seeing both ABS and PVC mentioned... if you're going to join the two, you need to use a mechanical connection. They cannot be glued.
2023 Airstream International 25RBT
2019 F250 XLT 6.7L Power Stroke Diesel
Bearstream01 is offline   Reply With Quote
Old 07-04-2022, 10:52 PM   #24
ITSNO60's Avatar
Tucson , AZ
This won't work?
Name:	abs to pvc.jpg
Brian
ITSNO60 is online now   Reply With Quote
Old 07-04-2022, 11:14 PM   #25
2007 25' International CCD FB
Glen Allen , Virginia
ABS socket Saver tool
This is the tool to ream out the ABS/PVC pipe, found on Amazon $20.
Jones Stephens J44300 J44-300 3" PVC Socket Saver, 3-Inch
Good luck
dabhunter is offline   Reply With Quote
Old 07-05-2022, 04:58 AM   #26
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Originally Posted by ITSNO60 View Post
This won't work?
I've used it with success in the past.
Richard
11018
richard5933 is offline   Reply With Quote
Old 07-05-2022, 12:57 PM   #27
kathfred's Avatar
2012 25' Flying Cloud
2001 19' Bambi
Fresno , California
Originally Posted by Trons4u View Post
Wow, what has happened to quality craftsmanship. Putting a little spit of construction adhesive on the piece of rubber to 'hold' it in place, and as MollysDad pointed out the two rivets. So the person installing the rivets failed, so did the painter.
This does not seem to be an issue of craftsmanship, this appears that the OP hit something with such force it broke the connection off pushing it up hard enough to make a dent and damaging the pull valve and box next to it. Personally, we would not even attempt to repair this ourselves, this is a dealer or JC repair IMO.
kathfred is offline   Reply With Quote
Old 07-06-2022, 06:53 AM   #28
Yes, we did a full walk through. I did not go Down on the floor and inspect the waste connection. I dumped the tanks once before the connection fell off. Everything seemed normal. I am baffled and will never know what actually happened.
I got all the parts and reamer yesterday and will attempt the repair this morning and will share.
Old 07-06-2022, 08:52 AM   #29
Mollysdad's Avatar
If you dumped the tanks, you had the fitting at that time, otherwise the hose wouldn't attach. Sometimes you never know. I have a dent in a spot that's almost impossible to hit.
Please let us know how it turned out. I'm curious.
My suggestions were to get you dumped once in order to get to the dealer for a real fix.
Old 07-06-2022, 10:50 AM   #30
Half a Rivet Short
2022 Interstate 24X
...... I dumped the tanks once before the connection fell off. Everything seemed normal. .......
Hi
That rules out this being a problem at the factory or at the dealer.
Since it's impact damage, you do need to really get under there and see if any of the rest of the parts are also damaged. The valve bodies, the pipes to the valve, the other end of the pipe you will be reaming out, and all the sports are "suspect" at this point. There's other stuff in there so who knows what else might be on that list.
Part of what you need to see will be behind the belly pan. An "inspection camera" from a big box store or from Amazon is one way to poke around in there without drilling out a bunch of rivets.
Old 07-08-2022, 05:11 PM   #31
Fixed
Thanks everyone for your help and guidance. The tube is fixed along with the bracket. I videos the entire process. 15 minute video.
https://youtu.be/BRxXBqlQ3L8
Old 07-08-2022, 05:24 PM   #32
Escape Pod II
John Ware's Avatar
2018 22' Sport
2022 23' Flying Cloud
Orange , Texas
Expertly done !
JEWare
John Ware is offline   Reply With Quote
Old 07-08-2022, 05:39 PM   #33
ITSNO60's Avatar
Tucson , AZ
Nice job! For future reference do your 1/4 turn as you are inserting the pipe all in one motion.
Brian
A hose is a hose is a hose Vitaver Plumbing - Systems & Fixtures 38 09-23-2020 11:41 AM
Help! 1961 Overlander Waste Valve-Hose Connection joeyoc Plumbing - Systems & Fixtures 4 11-15-2019 12:59 PM
2017 23FB International Signature waste hose storage cap keeps falling off, a... Elly Mae Waste Systems, Tanks & Totes 1 11-26-2016 03:26 PM
Help: Waste Valve handles broke! 3campers Plumbing - Systems & Fixtures 6 07-19-2013 05:52 PM
Waste Water Adapter - mine broke off tslaven Waste Systems, Tanks & Totes 4 08-05-2012 12:29 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
