Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 09-27-2021, 05:41 PM   #1
2021 16' Bambi
Kerrville , Texas
Voyager Wireless Observation System
My 2021 Bambi has this system factory installed...camera at rear of trailer, wireless monitor to sit on dash of tow vehicle. When paired, the picture on the monitor has streaks of lime green and blobs that come and go and block the view of the images in the monitor. While driving, the view of the road behind alternates green and normal...like driving over a checkerboard. Has anyone else had a similar problem? Help!
Diane P
phildi is offline   Reply With Quote
Old 09-27-2021, 06:56 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Pretty much all trailer cameras have "issues" light comes in from an odd angle and the freak out a bit. What you are seeing is not unusual.
Old 09-27-2021, 07:48 PM   #3
2017 25' International
West Lake Hills , Texas
I like my HaloView M10 on its first trip this week. The monitor hooks on the stock rearview mirror. Wireless to the camera. I power the monitor from the stock mirror. Easy installation on the trailer if you don’t mind snipping and crimping a few wires. For the camera I used the existing Voyager power which is tied to the running lights (or seems to be). The monitor is in a muscle-memory place to see what’s behind your rig. New TV has integrated trailer camera but I have not looked into it.
Caveat…too little data at this point to unequivocally recommend it. I haven’t had the camera in enough variations of glare. It was south-facing afternoon sun the entire trip. The monitor has more glare than I would like but I think I can remedy that.
Fungus is offline   Reply With Quote
Old 09-27-2021, 08:09 PM   #4
2017 28' International
Jim Falls , Wisconsin
I have the same system. I recently had to replace the camera due to moisture inside it. Other than that it has worked fairly well. It isn’t like looking out the rearview mirror however. But it is sufficient to get a look at what is behind me. But I would call the camera company and ask about it. You might be able to get a new camera. They were pretty helpful when I was installing mine. You should be able to get a clearer picture.
Daquenzer is offline   Reply With Quote
Old 09-28-2021, 07:26 AM   #5
2021 16' Bambi
Kerrville , Texas
Thanks for the responses. The green issue on the monitor is not a matter of glare on the camera, as it is there even when parked in storage shed. I did reach out to the company and the rep seemed pretty baffled at what I described...said it is not a common issue...and suggested I take it to an Airstream dealer to trace the problem. I guess that is my next step.
Diane P.
Diane P
Old 09-28-2021, 10:38 AM   #6
Another thing about the HaloView is that it is a dash cam, too.
Only $210.
Old 09-28-2021, 11:05 AM   #7
2015 30' International
FREDERICK , Maryland
I had a Voyager wireless backup camera installed by an Airstream dealer 3 years ago. Though the display is a bit clunky in size, it provides an excellent picture and has been quite reliable. I would suggest taking a picture of what the image on your display looks like (if it show up well in a photo) and email it to the manufacturer.
Doc Foster is offline   Reply With Quote
Old 09-28-2021, 03:01 PM   #8
2019 25' International
Providence , Senior Electrical Engineer
Sounds like the digitizer from the camera's image sensor that creates the Bayer pattern may have an issue (Bad/cracked solder joint). Usually there is a CPLD or FPGA to convert the Bayer pattern to a usable video stream that is sent to the monitor for reconstitution of what the image sensor "sees".
https://en.wikipedia.org/wiki/Bayer_filter
The problem is figuring out the culprit, the sender (image sensor) or the receiver (LCD monitor) of where the stream is corrupted.
If I had to "guess"....it is most likely the camera itself.....those things are not sealed good from the factory. Our 2019 Serenity has already had the camera replaced due to water ingress...not saying that is what is wrong with yours...but if I was a betting man....replace the camera side of the equation and it all goes away.
kittmaster is offline   Reply With Quote
Old 09-29-2021, 12:27 PM   #9
SPW
1987 29' Sovereign
2016 30' Flying Cloud
Atascadero , California
I too have the Voyager system installed by Airstream dealer and do not have the problem you described--we are happy with the system. I agree the problem you describe is not caused by the glare that sometimes is a different issue. Sounds like the problem is with the installation or the Voyager system--it may be hard to determine which. Presumably the system/install is still under warranty and I suggest that you have the dealer make it right.
SPW is offline   Reply With Quote
Installation of Voyager Wireless Observation System jwschnettl 1956 - 1965 Caravel 3 05-16-2023 10:09 AM
Voyager Rear Backup Wireless Camera System WVOS511 moosetags Airstream Classifieds 0 04-13-2018 01:31 PM
New WVOS43 - Voyager Digital Wireless Observation System AStreamNerds Electronics & Connectivity 9 04-10-2017 09:42 PM
Voyager wireless camera DeltaRon Electronics & Connectivity 6 06-16-2015 06:32 PM
Voyager compatible wireless monitor Gneiss Guy Electronics & Connectivity 0 09-16-2014 02:22 PM
