Old 12-07-2021, 07:17 PM   #1
2016 23' International
Los Altos , California
underbelly freshwater shield?
HI, just purchased a 2016 23FB and needing to run some wiring from AC-DC panel under belly to front (under bed) I see there is a metal shield that I assume is protecting the fresh water reservoir under belly. It's held on by fairly decent size bolts. Has anyone removed that metal shield? If I remove with the exposed bolts, will it also drop the water reservoir? i don't want to do that. I just want drop some heavy gage wires down to the belly and route to bed
jsmall01 is offline   Reply With Quote
Old 12-08-2021, 06:37 AM   #2
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Yes, the fresh water tank is inside that metal "enclosure." If you remove the bolts it will all drop down.
There is a dedicated 23FB thread here on the forum. You might check there... probably your very best bet for gletting a solution.
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 12-08-2021, 06:46 AM   #3
Just me again...Wouldn't it be easier & more accessible for a possible future repair,(diagnosis), to run the wiring in pvc conduit?
Old 01-14-2022, 06:25 AM   #4
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
that what i would do as well.. get some 3/4 or 1" plastic conduit on the back side of the tanks to help protect it.. but that stuff is quite tough by itself.. and run the wires inside that.. you can get some nice long sweep 90's and other stuff to make the install nice and protected.. take a walk around the elec isle in a large home depot store. there is a ton of stuff to use.. (former HD elec dept worker bee)
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 01-14-2022, 06:43 AM   #5
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Or just use some flexible PVC conduit. Should be able to snake it from point A to point B easily. With the proper end terminations it will keep out the elements and protect the conductors.
Richard
11018
richard5933 is online now   Reply With Quote
Old 01-14-2022, 07:01 AM   #6
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
I have a 27' but I ran my solar wiring from amidships to the front where the 12VDC buss bars are. I used standard flexible conduit. I hung it under the trailer on the street side but a buddy who does AS repair saw my solution and made it one better in his solar adds by dropping the banana wrap and running the flexible conduit inside the outriggers of the frame. There are cutouts in that with flattened edges that you can pass through. Makes it real slick and invisible. - Brad
SuperTrouper is offline   Reply With Quote
Secondary Freshwater Tank or Convert Grey/Black to Freshwater LiamG Waste Systems, Tanks & Totes 24 01-13-2019 07:55 PM
"Shield" Brand Tires?? Jason1101 Tires 3 08-18-2009 06:30 PM
Transit Shield exterior protection 63air Rock Guards, Segment & Window Protectors 1 01-21-2006 08:45 AM
2004 International CCD Rock Shield andyfuson Rock Guards, Segment & Window Protectors 9 11-17-2004 09:56 PM
Repair cracked rock shield? Rog0525 Rock Guards, Segment & Window Protectors 5 07-12-2003 12:53 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
