08-10-2004, 08:43 AM
Just a member
1978 28' Argosy 28
Lutz
Umbilical Wiring Diagrams
Here are links to 4 Pd's, the titles encompass the years.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
10-31-2005, 08:16 PM
1982 31' Airstream 310
Longview
I been working on 18 wheeler for year and that not the color code for the wire and that not the way we wire are burg plug. I going to keep this so if I have wire up a trailer I have it. Thank's
11-01-2005, 04:01 AM
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Love the PDF! This is what I have found for my 70's, little more detail.
Thanks for posting the PDFs, they will go on my Manual CD
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
10-22-2006, 06:07 PM
A 7th year newby
1968 24' Tradewind
Indianapolis
, Indiana
Thanks for the PDF
Hi,
Thanks for the PDF on the 66-81 umbilical wiring diagram. Just checking -- this should go for the 68 Trade Wind 24 ft. Land Yacht.
I just had to pay some good money I could have used for POR-15 because I connected something wrong from my new/vintage 68 Trade Wind to my Jeep's towing package outlet. I blew some fuses, kicked on the check engine light. I think I will leave the AS in the driveway while I rewire the umbilical.
I have the AS plugged into the house at the moment, but I don't know how long that will last because I see in another forum that I should be suspicious of the Univolt's monitoring of the battery charger while leaving the AS connected long-term.
I saw all the back-and-forth about the Univolt, so I don't want to stir up those hornets. My first simple question is, where is the Univolt supposed to be on the 68 Trade Wind, 24 ft, twin model?
Second question, maybe not so simple is, how do I change the Jeep's receiver for the 7-way plug to match the AS 7-way so's I don't make the same mistake again, and throw good money after bad?
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
10-22-2006, 07:41 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings seattlebound!
Originally Posted by seattlebound
Hi,
Responding to your second question first, many of us prefer to rewire the Airstream to match the current Industry Standard for the Bargman plug rather than rewiring the tow vehicle. There are two reasons for doing so. The first is that it will simplify towing other trailers that you may want to two along the line as nearly everything today is wired to the industry standard. The second reason is that in an emergency situation, it will be much easier to find someone equipped to tow the coach if it has the Bargman wired to the industry standard rather than to the Airstream unique pattern.
I am not certain where the Univolt is located in the post-1965 coaches, but in the earlier 1964-1965 it was typically in the streetside corner of the one-stop service center.
Good luck with your Bargman connector wiring!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
10-22-2006, 08:58 PM
A 7th year newby
1968 24' Tradewind
Indianapolis
, Indiana
bassackwards
Hi, Kevin, your response is very helpful. Of course, I would try the opposite first...
I suppose I could re-fit the adapter to correspond to the standard. The first post in this thread has the diagram of my year's connector, so I just need to be sure I can adapt the business end of the AS wiring to the standard, right? Better yet, I think I will just take the whole thing to an expert to be sure it's safely connected. I have to accept that I cannot do some things by myself, especially electrical work and welding. I do pretty well at repairs, but a retro-fit is scary.
Anne
Dayton, OH
Kevin
Anne
Indianapolis, IN
TAC IN-7
10-22-2006, 09:09 PM
1978 31' Excella 500
Venice
to paraphrase Eastwood's rule: "A person's got to know their limitations."
Often a mistake in electrical wiring becomes welding!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
10-22-2006, 10:32 PM
A 7th year newby
1968 24' Tradewind
Indianapolis
, Indiana
MarksRV.com
This site is excellent for making the update to bring the vintage AS connection to industry standard:
http://www.marksrv.com/wiring.htm
Anne
Indianapolis, IN
TAC IN-7
11-11-2008, 09:33 PM
1975 23' Safari
Portland
, Oregon
Two Quick Questions:
1. The above diagram in Post #1 of this thread refers to the pin-out based on facing the male connector mounted on trailer, correct?
2. It does not refer to the female connector on the cable that plugs into the trailer, correct?
I'm having trailer electrical issues and just want to start from a known good state.
Ron
03-28-2009, 10:56 AM
1969 31' Sovereign
Chateauroux
, Indre
Umbilical "special" connection
Hi,
I have a 1969 Sovereign that I rent as a "static" guesthouse ..no towing. I would like to put a switch outside to light up the taillights and clearance lights at night for the guests, anyone have any ideas?? Maybe take the 12 volt juice from the electrical jack and shove it in the connector somewhere?
Mike
03-28-2009, 05:54 PM
North Ogden
, Utah
Tail Lights & Clearance Lights
These lights are powered from the "Tow" vehicle. Based on past comments in the Forums Airstream has used various versions of the 7 pin connector. But be as that may be you should be able, with some clip leads/probes, determine which pins on the plug feed those lights. (use a source of 12 volt power)
Once you have made this determination mount a waterproof connector box where the trailer plug can be stored inside. Then mount your waterproof switch and connect wires to the predetermined connectors.
On my 2003 Classic the wiring for the lights, at the plug view, shows the lights feeding in on the 1st pin to the right of the alignment pin. The gnd is 3rd pin cw from there. This may be different from your unit
Cal
03-30-2009, 01:11 AM
1969 31' Sovereign
Chateauroux
, Indre
Thanks for the infos!
I found the pin that connects to the clearance and taillights! All I need is to get the 12 volts from the jack and a switch......looks cool in the dark!
Mike
03-30-2009, 04:54 AM
2006 30' Classic S/O
Mohrsville
, Pennsylvania
Mike
Mike,
You don't need to tap into the jack wiring, you can get the 12V from the trailer umbilical. In this diagram you can jump position 3 & 4 and your tail and marker lights will light. Some folks here have made nifty switch boxes to accomplish what you are trying to do. If I can find the thread I will post the link.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
03-30-2009, 05:30 AM
Mohrsville
, Pennsylvania
Mike,
Here is the thread to "keeping your running lights on." You can see all the inventive ways people have accomplished this. I especially like robertsunrus' gadget.
http://www.airforums.com/forums/f447...-on-35681.html
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
03-31-2009, 12:03 AM
1969 31' Sovereign
Chateauroux
, Indre
thanks
Hey....you are the best!
