Old 06-20-2021, 11:23 AM   #1
2021 27' Globetrotter
Piedmont , South Carolina
Twin bed air gap
Thought I would alert others who have a twin bed trailer. We have a 2021 Globetrotter FBT. We recently noticed significant open gaps at the foot , (from the foot toward the middle) where the bed platforms are attached to the outside. With the outside bins open you could see through to the outside. On one platform the gap was 3/4” !
After a trip to Home Depot for supplies, the gaps have now been insulated and sealed.
Obviously, there was no inspection of this.
Trailride is offline   Reply With Quote
Old 06-20-2021, 04:30 PM   #2
pjshier's Avatar
2017 27' International
Wasilla , Alaska
same thing 2017 27FB
...and responded the same way: found some suitable foam trim and filled the gaps. Stays put. Not sure it is a design flaw or mfg. defect as much as a mfg. tolerance issue arising from hand-made construction.
Cessna parts suppliers tried shipping parts with rivet holes predrilled until it became obvious that none would fit.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 06-20-2021, 05:23 PM   #3
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
I killed 2 birds with one stone while dealing with this issue.
The twin bed platforms on our 2020 25' Globetrotter allowed the mattresses to stick out over the edge. This lack of support made it quite uncomfortable to sit on the edge of the bed.
I unscrewed the platforms and used the curved edges as templates to cut out approx. 6" wide strips of 3/4" finish plywood. Applied foam insulation to the edges of the strips then screwed the strips down next to the wall followed by the original platform next to them, with the factory molding facing toward the aisle.
The gap to the wall was thus filled, the platform was widened to better support the mattresses, and the original factory look of the platform edge was retained.
Mike
“The thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2020 25' Globetrotter Twin
2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string
580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 06-20-2021, 08:55 PM   #4
TexasVine's Avatar
2021 27' International
Fredericksburg , Texas
Interesting, I will be taking a look at my 2021 International in the morning to see if I will encounter the gap issue.
TexasVine is offline   Reply With Quote
Old 06-21-2021, 05:48 AM   #5
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Are we talking about the platform the mattresses sit on? If so, seems like they've installed them with a gap for decades. My 1994 Excella has a gap at the end of both mattress platforms, but it only opens to the storage compartment below. No access to the outside through the gap, and as long as the seal on the outside door is intact there is really no problem. I always thought that having some air flow in/out of the storage compartment was a plus to keep things from becoming moist in there.
Richard
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 06-21-2021, 09:50 AM   #6
TexasVine's Avatar
I checked have zero gap under the twin beds to the outside.
Per richard5933 response, are you talking about a gap the upper part platform? if so, there would be no need to seal the gap.
Old 06-21-2021, 11:27 AM   #7
2019 25' Flying Cloud
West Windsor , Vermont
We did what mikeinca did a couple of years ago. I went easy on the insulation after noting the condensation concerns several owners experienced. That floppy mattress overhang annoyed me. Several people built up an extended second layer of plywood with an airspace between.
Peterf is offline   Reply With Quote
Old 06-21-2021, 01:32 PM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I didn't think adding that extra 3" of width for the mattress would make much difference- until I did it!
2019 Ford Expedition Platinum
Old 06-21-2021, 02:27 PM   #9
2020 23' Globetrotter
Savoy , Texas
Our 2020 GT FBT had the same mattress overhang and gap to the outside wall. We removed the original mattress got some 3/4 thick plywood. Used the original for a pattern to cut the curve, slots and added 3 inches to support the mattress. We put more foam to seal the outside gaps where needed.
SpinWhite is offline   Reply With Quote
Old 06-24-2021, 12:47 PM   #10
Kinnelon , New Jersey
Interesting indeed. We picked up a new 2021 GT 25 FBT. On our first trip in the Northeast in April (when temperatures were still in the 40s at night), we noticed a nasty draft from the exterior wall along the mattresses. I just assumed it was due to the AS not being that air tight. If this is the reason, it now makes sense (and also seems to highlight a design flaw).
Jason P M is offline   Reply With Quote
Proper foam board material for creating Reflectix air gap? zen_stream General Repair Forum 16 01-31-2021 10:59 PM
Convert twin bed to a king bed ridgwayk General Motorhome Topics 7 04-01-2019 07:46 AM
Will a regular air bed work on a FC front bed twin? atheness General Interior Topics 0 09-04-2018 01:26 PM
need a little help here.. changing Twin bed to queen bed.. carl2591 General Repair Forum 3 01-13-2016 07:16 PM
Excella 34'- twin bed to full bed conversion??? SilverStone Interior Restoration Forum 0 10-30-2014 04:21 PM
