Old 06-09-2021, 07:42 AM   #1
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
Trim band coming off...
My lower trim bands were hanging down on both sides of my AS this morning, so I pulled them all off. I know some of you may have had similar issue. I am going to JC in October, but curious on a fix if we want to reinstall before then? What did you use, (3m 2 sided tape? if so, which one?) If you did go thru this, what did you use to clean up and which tape/ and size of tape did you use? (sorry- just noticed picture came in sideways...; but thats an easy fix...just tilt your head! LoL) Thanks for comments in advance...we are on the road to WY out of Lubbock this morning...
2017 28' Twin Flying Cloud
Old 06-09-2021, 08:45 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Mine were faded out, but still holding tight. I have 1/2" trim and 1" trim. I pulled it all off, cleaned all the old stuff and installed new. The new has double sided tape install on the trim. Found the trim I needed here:
https://woodlandairstreamparts.com/search?q=trim
Richard
Old 06-09-2021, 04:29 PM   #3
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
Our trim was still like new, and only part of it was coming off so I used gasket adhesive. One of the factory techs suggested it.
2017 27 Tommy Bahama
2020 2500 GMC Duramax
rperrym is offline   Reply With Quote
Old 06-10-2021, 01:26 AM   #4
2016 23' International
Thousand Oaks , California
I have a spool of the stuff left over from when I replaced the whole belt line on our trailer.
If you’d like some short sections of it then pm me and we can work something out.
Seanlb is offline   Reply With Quote
Old 06-10-2021, 05:20 AM   #5
ShawnSk's Avatar
2021 20' Bambi
FREDERICKSBURG , VA
What's the best way to cut this and get a clean edge?
ShawnSk is offline   Reply With Quote
Old 06-10-2021, 06:13 AM   #6
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
An "anvil" pruned works great.
https://www.amazon.com/Fiskars-91105...14800402&psc=1
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 06-10-2021, 09:44 AM   #7
Denver , Colorado
What kind of gasket adhesive did you use? Same thing is happening to mine
Troyann is offline   Reply With Quote
Old 06-10-2021, 10:38 AM   #8
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Gorilla brand double sided tape available in the paint department of most big box stores. Comes in the correct width and works great. --Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 06-10-2021, 11:05 AM   #9
rperrym's Avatar
To Troyann
I used 3M black Super Weatherstrip and gasket adhesive. Comes in a tube.
Old 06-10-2021, 01:08 PM   #10
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Trim replacement is a recurring topic and the forums' search function will reveal a variety of insights. If your "chrome" is cloudy or damaged then replacement is warranted versus just re-adhering it.
The original product is 1" wide Cowles' Proteckto trim with Chrome finish and comes with the adhesive mounting tape attached. The product number 37-315 is a hundred foot Chrome roll (great for longer trailers), 37-314 is the fifty foot chrome roll and enough for Bambi's or just a section. If you have a hankering for a different color be advised there is quite a selection from black to blue to red, etc.
Here is a link to a sample source:
https://www.ebay.com/itm/233806799388
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 06-10-2021, 03:21 PM   #11
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
I had the same issue.
I used 3M VHB to reattach our trim, with good results. Make sure to remove the old tape with a putty knife first.
VHB is meant to be permanent.
Description:
3M VHB 4910 Heavy Duty Mounting Tape - 0.75 in. x 15 ft. Transparent Double Sided Tape Roll. Tapes and Adhesives
Amsterdamer is offline   Reply With Quote
Old 06-10-2021, 03:28 PM   #12
VDR928's Avatar
2012 23' FB International
Charlotte , NC
I removed all our old rub-rail and belt line, cleaned well with alcohol, and replaced with new. I bought both from Out-of Doors-Mart, and you must roll them firmly to get a good adhesion. Worked great and looks great!
VDR928 is offline   Reply With Quote
Old 06-10-2021, 05:46 PM   #13
The absolute best way to get a clean cut is to use a pex pipe cutter.
Old 06-10-2021, 06:04 PM   #14
2002 25' Safari
Dewey , Arizona
Images: 62
I replaced all mine this year. It had become a cloudy white color and was just ugly. I tried a few different methods to cut and found a good pair of tin snips worked the best for me. Utility knife was hard to get a straight cut and any type of saw did not cut very clean.
Richard
Old 06-16-2021, 10:39 AM   #15
2017 Interstate Grand Tour Ext
CANON CITY , Colorado
2017 AI came lose just below the fuel door, looks like the diesel got to it. Clean it good with alcohol, and use gorilla original glue, and hold it in place with masking tape till set, diesel will not effect Gorilla original glue once set.
Blazeman1 is offline   Reply With Quote
Old 06-16-2021, 02:20 PM   #16
Old dog new tricks
2017 19' Flying Cloud
Banner elk , North Carolina
Easy fix
We used E6000, my all time fav adhesive and put a piece of tape over it til dry. Didn’t leave tape on long enough to leave adhesive behind. Just repaired about 3-5” where falling.
Ours too is cloudy and I’d love a custom color trim….short of painting it and ideas?
Flying Pig is offline   Reply With Quote
Old 06-18-2021, 07:46 PM   #17
1998 31' Excella 1000
Simpsonville , South Carolina
Trim band
I've used 3M VHB 5952 1"×7" very successful to bond my brackets that hold my Renogy 100 watt solar panels on. I check them regularly, but they have been secured since 2017 and about 25k miles of traveling. My brackets were 1"×6" is why I got that size and cut off the extra inch. Got from Amazon, I think. Let us know what and how you solve this issue, I'm thinking about replacing mine. Good luck.
sctinman44 is offline   Reply With Quote
Old 06-19-2021, 05:38 AM   #18
RFP
RFP's Avatar
Hurst , Texas
When the trim started coming off of our 2014, I replaced it with black. It looks great, kind of "dressy." We bought it from a lcal dealer for these products: http://www.trim-gard.com/bodysidemoldings.html . Good selection of other colors, too.
And some stuff
Old 06-19-2021, 09:35 AM   #19
gypsydad's Avatar
Well thanks alot!!! You had to mention "different color" option! Wife is now involved...this could take awhile to decide...mood dependent now it seems!
Old 06-19-2021, 11:09 AM   #20
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
well thanks alot!!! You had to mention "different color" option! Wife is now involved...this could take awhile to decide...mood dependent now it seems!
lol.....
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement EZ-Lift WD with 2 Anti Sway Bars. previous tow vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L
Ultraclassic is offline   Reply With Quote
Rivet popped, Trim coming off on door Cdn Camper Ribs, Skins & Rivets 1 05-26-2020 11:55 AM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 10:00 AM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 07:06 AM
Belly Band on 31' 1978 Exella Jim Miller Belly Pans & Banana Wraps 12 04-06-2003 04:18 PM
Bottom Band ? SAM Belly Pans & Banana Wraps 2 09-28-2002 08:33 PM
