I noticed the brakes on the trailer were not effective; I could barely feel any braking when manually engaging the trailer brakes. I took it to the dealer who examined the brakes, reported they were dirty, cleaned them and also repaired a broken wire. On the way home I again tried the brakes manually and they were stronger than before but still minimal. The manual for my brake controller says I should be able to lock the wheels on the trailer but that is not even close. I have an appointment to go back to the dealer but they don't really seem to have a plan in mind. Thoughts?
Mine will not lock up the brakes on a solid surface with the manual lever. The one time I really stood on the brakes while towing, it did lock up — I believe it is simply the nature of a proportional controller.
My controller manual calls for a test a 20 mph with a brisk (not instantaneous) application of the manual lever. You should feel significant deceleration.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
