07-25-2014, 09:56 AM
2010 28' International
2009 17' Sport
Boerne
toilet leaks at flush valve
2010 International 28' Leaking toilet , the small black cap on bottom of flush valve leaks slow drips, black cap doesn't seem to be threaded on, it looks like it is glued on, anyone ever run across this leak before?, would appreciate any hints, tips, fixes, etc.
John
07-27-2014, 07:16 PM
1987 32' Excella
Nepean
Can you please be specific as to the brand and model number of the toilet. As well, a photo of the valve showing where the leak is will help.
Generally, any kind of valve leak results in changing the valve itself. Basically, the mechanism pushes in a button which opens the valve to admit fresh water to flush the bowl. Different models and makes use different valves, most of which can be purchased online through Amazon or, if you don't mind paying more, from an RV dealer.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
07-27-2014, 09:40 PM
1976 Argosy 22
cranbrook
, British Columbia
Had a similar problem this spring when we turned the water on. The toilet had a major leak, only when you flushed. If you didn't touch the foot flush, no problem. Took the toilet out, found the leaking part. The washer on this stem had turned to jelly. According to the manual the washer was in the vacuum breaker. The Aqua Magic is 38 years old, I took a chance at the RV store with a current Aqua Magic rebuild toilet kit and there it was, the washer that had turned to jelly. Lots of parts I did not need or would fit my older toilet. 25 bucks later up and running no leaks.
08-18-2014, 05:34 PM
2009 17' Sport
Boerne
I removed valve, found hairline crack, tried to seal w/ epoxy, did not stop leak, How do i identify the make/model number of toilet? here is pic of valve, https://www.flickr.com/photos/126986291@N05/
08-18-2014, 10:26 PM
1987 32' Excella
Nepean
VE3JDZ
AIR 12148
WBCCI 8080
08-19-2014, 09:33 AM
2009 17' Sport
Boerne
Thanks blkmagikca...... That looks very much like the one i got,,,only thing that worries me a bit, is that mine has only the two mounting holes, The one on Amazon appears to have a third hole at top left side If you look at the my pic on flickr w/ part number, the third hole is also there, just seems to be not used w/ plastic over it.... Anyway i am going to buy it... Thanks for your help!
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Leaks, Leaks and more leaks
Jim in Pima |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
5 |
12-12-2007 11:23 AM |
Leaks, leaks, leaks
jeffnjen30 |
8 |
08-27-2007 11:03 PM |
leaks leaks leaks
Globie64 |
10 |
12-31-2005 05:49 PM |
No Fuss Flush Leaks!
dpope |
2000 - 2004 Safari |
7 |
06-25-2005 02:48 PM |
Black Water tank flush leaks
bfwoz |
Waste Systems, Tanks & Totes |
2 |
07-06-2004 04:06 AM |
