Old 05-26-2020, 09:01 AM   #1
Spruce , Michigan
Tire Change or Not?
file:///Users/bauerg/Downloads/20200...02_resized.jpg
Just got a call from the mothership. They found a bolt through my tire. Hopefully the picture will show up in this message. What do you think, should I replace the tire?
Hard to imagine it didn't blow or deflate. . . . Sometimes you get lucky as we may have had it in there for over 300 miles.
Bauerg is offline   Reply With Quote
Old 05-26-2020, 09:17 AM   #2
2007 22' International CCD
Time for at least one new tire. And a gentle thank you to the gods that kept it from causing a big problem!
rmkrum is online now   Reply With Quote
Old 05-26-2020, 09:26 AM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Buy a new one, and if the rest are more than 4 years old, replace them all. Say a little prayer of thanks that the tire didn't blow. A TPMS is also a wise investment.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is online now   Reply With Quote
Old 05-26-2020, 09:52 AM   #4
jaybauman's Avatar
2019 30' Flying Cloud
Katy , Texas
I've had a similar experience with my TV, where a bolt was "fully integrated" into the tire with no apparent loss of air pressure over, presumably, a few hundred miles. I think it's incredible that the bolt seals so well against the tire.
That being said, your tire was not constructed for permanent use when the belts have been pierced like this. Replace it and be thankful that you discovered it this way instead of in some other catastrophic manner.
2019 Flying Cloud 30FB Bunkhouse
2020 GMC 3500HD Duramax AT4
ProPride 3P w/ 1400 lb. spring bars
jaybauman is offline   Reply With Quote
Old 05-26-2020, 01:19 PM   #5
Spruce , Michigan
Actually, the trailer is a 2019 we bought in December. Haven't checked the age of the tires, but I would assume that they are not that old. Of course I told them to replace it. I might mount this and hang it on the wall of my garage as a trophy - what do you think?
Old 05-26-2020, 02:09 PM   #6
2019 25' Flying Cloud
Hendersonville , North Carolina
Bolt in tire
Wow! Chalk one up for the Goodyear Endurance tires AS are now equipped with. That is really something that it did not have failure and tear up the wheel well.
Nice trophy for the mancave and quite a conversation starter for anyone that sees it. Buy a lottery ticket. You are a lucky AS owner.
uraljohn is online now   Reply With Quote
Old 05-26-2020, 04:02 PM   #7
richw46's Avatar
Lexington , Kentucky
It's probably a grade 5 or higher bolt, they're self sealing.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
Most of us don't know exactly what we want, but we're pretty sure we don't have it. -Alfred E. Neuman
richw46 is offline   Reply With Quote
Old 05-26-2020, 05:35 PM   #8
Ultraclassic's Avatar
2000 30' Excella
GTA , Ontario
Oh my god, do you have to ask? Oh ok your just kidding right....no really that tire is compromised beyond repair.
Tow Vehicle 2005 Ford F150 Lariat 367,000Kms 5.4L - 2012 Mercedes Benz GL350d - [not set up yet]
Ultraclassic is offline   Reply With Quote
Old 05-26-2020, 05:38 PM   #9
2000 30' Excella
GTA , Ontario
Great idea, maybe to keep the weight down you could get a hi res photo zoomed in and plak-it , this would make a awesome guy talk for a least 2-3 beers
Old 05-26-2020, 10:54 PM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Second the motion to buy a lottery ticket! Your Karma is strong, Grasshopper.
Foiled Again is online now   Reply With Quote
Old 05-27-2020, 09:21 AM   #11
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
AH! yah! time for a new tire ... if the rest are close to 4 year old buy the whole set - tires $700.00 - cost of repair to Airstream because of blow out $7000.00 IMHO call it cheap insurance.
La Dolce Vita Brick & Mona
We're Married With Airstream
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 05-27-2020, 10:32 AM   #12
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
If you have to ask, change it.
Cost vs benefit/safety, you choose.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 05-27-2020, 10:37 AM   #13
Boxite's Avatar
2008 22' Sport
Absolutely NOT!
With Luck like your’s you should sell the RV and go to Vegas.
Old 05-27-2020, 11:50 AM   #14
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
You replaced the tire, obviously. Now get a TPMS so the next time you acquire a bolt in the wrong place, and it leaks, you’ll know about it! We use TireMinder.
banderabob is offline   Reply With Quote
Old 05-29-2020, 12:44 PM   #15
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
WOW. It’s amazing how stuff like that can happen, in there sideways?
bibbs is offline   Reply With Quote
Old 06-03-2020, 11:56 AM   #16
Redmond , Washington
Great example to illustrate the value of TPMS. I will be installing one soon. Though I check tire pressure before every trip and torque lug nuts at least every week or so while on a trip,, I just discovered a screw in my tire tread upon routine inspection. There was no obvious appearance change in the tire but pressure was 28 lbs. (80 recommended for the Goodyear Endurance tires on my 2019 25’ FC). You cannot “see” low pressure.
I was actually lucky to have this puncture (and to discover it). When I refilled it and drove 2 miles to my local Les Schwab tire dealer they discovered that my shock absorber on that tire had lost a nut and was hanging free.
Les Schwab fixed the tire and replaced a nut without charge - even though these were the original tires not purchased at their store.
Here’s my disappointment. Because Les Schwab didn’t have the correct nut they suggested I go to the nearby Home Depot for a replacement. Fortunately, to help me they removed a matching nut I could take for comparison. HD didn’t have the correct nut so I drove 8 miles to a specialty fastener store. Meanwhile I called Jackson Center and gave them my AS VIN and asked for the correct size to request at the specialty store. They told me it was a “5/8 flanged hex”. When I gave the clerk at the store the actual nut to match for the replacement he returned with a 1/2 “ nut. I questioned him and he demonstrated on a gauge that this was indeed a 1/2” nut that was on my AS. I thanked him and returned to Les Schwab where they easily installed the 1/2” nut and the one they had removed as a sample.
Bottom line - despite the wonderful stories I’ve heard about Jackson Center, I was disappointed with their inaccurate information that could have been very inconvenient had Les Schwab not had the foresight to provide me an actual sample of what I needed.
WestieHouse is offline   Reply With Quote
Old 06-03-2020, 12:09 PM   #17
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
I'm impressed it didn't fail. What model tire is it?
Mike G is offline   Reply With Quote
Old 06-03-2020, 01:24 PM   #18
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
...junk..install spare...use this as the spare..if they can fix it
Old 06-04-2020, 07:45 AM   #19
richw46's Avatar
When I first got my AS I didn't know anything about where things were. I emailed them and asked how to get to the water pump so I could winterize. They said I needed to raise the floor of the closet and it would be underneath. Well that floor was screwed down so I knew it couldn't be the access. It was a panel just below that but with no handle. I pried it open and had the access I needed. I've continued to contact them about other matters and I get a good answer about half the time. It can take them quite a while to respond too.
-Rich
Rich & Yvonne
2004 4Runner SE
Damages sidewall & Tire Change due to "Evil Rock" with pics.... JFScheck On The Road... 40 04-24-2013 08:43 AM
Not tire rating, but tire weight boondockdad Tires 9 10-13-2011 01:48 PM
Change a tire friedablue Jacks, Stabilizers, Lifting and Leveling 8 08-04-2010 03:26 PM
tire change from 16" to 15" Benjo Wheels, Hubs & Bearings 7 04-24-2009 11:17 PM
Have you ever tried to change a tire on an Airstream? Globie64 Tires 12 02-20-2008 12:13 PM
