Old 02-09-2020, 07:51 AM   #1
2017 22' Sport
Renton , Washington
Tire Advice--Post lift
Hi Forum!
Just had my 2017 Sport 22 fb lifted 3 inches. I still have the stock tires on the trailer (Goodyear Endurance). I am wondering if there would be any negative impacts in switching to a Goodyear Wrangler type tire.
I am wondering if the more robust treads on the Wrangler would have any unintended consequences.
Thoughts?
Glampman
Name:	Goodyear Endurance.PNG
ID:	360793   Click image for larger version
Name:	Goodyear Wrangler.PNG
Glampman is offline   Reply With Quote
Old 02-09-2020, 10:23 AM   #2
batman's Avatar
1964 22' Safari
modesto , California
Originally Posted by Glampman View Post
Hi Forum!
Thoughts?
Glampman
One concern might be the load carrying weight limitations of the Wrangler tire. I am not familiar with them.
The aggressive tread is not necessary on a trailer, but may help in a muddy side hill or slippery down grade. Situations best avoided if possible but if your boondocking and the weather turns and you have to get out. I get it.
A good E rated tire and strong wheels. A lot of folks have gone 16" Michelins and never looked back.
-Dennis
batman is offline   Reply With Quote
Old 02-09-2020, 10:34 AM   #3
batman's Avatar
1964 22' Safari
Fyi
We are lucky to have two tire engineers here on the forum. Tireman9 and Capriracer. They both are invaluable resources and much appreciated here.
Try http://www.rvtiresafety.net/ or http://www.barrystiretech.com/
-Dennis
Old 02-09-2020, 10:49 AM   #4
"Cloudsplitter"
I have always preferred/used a tire designed for trailer use.
The Wrangler will have a considerably more flexible sidewall not particularly good for trailers, especially ones with more than one axle.
Two Seasons, 12k on our GYE....👍
Old 02-09-2020, 11:18 AM   #5
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Stick with a tire designed for trailers
Glampman, great question! If there was a Wrangler rated for trailer service you could consider it. That said, the Wrangler you're looking at is not trailer-rated while your current Endurance tires are. I agree with Robert Cross - stick with what you have.
Airstream posted a Knowledge Base article about the subject: https://support.airstream.com/hc/en-...el-Replacement
I'd stick with what you have!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 02-10-2020, 06:49 AM   #6
CapriRacer
CapriRacer's Avatar
I'm in the , US
Try https://www.rvtiresafety.net/ or https://www.barrystiretech.com/
-Dennis
Thanks for the compliment. I'll try to live up to it.
Hi Forum!
Thoughts?
Glampman
[[Images deleted]]
First, you didn't state what tire size you currently have, but I'll bet that you won't find any Wranglers that have enough load carrying capacity in the current size.
But I'm thinking what you are considering is that the deeper tread would have more puncture resistance - and that is only sort of true. What really helps is lower inflation pressure - BUT - you need to keep the pressure up for load carrying capacity - UNLESS - you go to a larger size.
And that's what I recommend you do.
CapriRacer
Want to learn about tires? Please visit my website: Barry's Tire Tech New content every month!
CapriRacer is offline   Reply With Quote
Old 02-10-2020, 07:56 AM   #7
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Plus, tires with aggressive treads tend to pick up and throw larger rocks causing dings.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Tire blow out took out rocker panel behind tire, need advice / suggestions ClayDC Belly Pans & Banana Wraps 17 09-07-2021 06:40 PM
Should i lift the shell or not lift the shell.. prettybrent Repairing/Replacing Floor &/or Frame 19 09-04-2016 10:13 AM
1997, 34ft Classic: To Lift, or Not To Lift (its shell) mattler General Repair Forum 4 10-16-2015 10:40 PM
Air 'Bags' - too lift or not to lift JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 04-09-2013 10:09 AM
