10-13-2020, 03:56 PM
2021 16' Caravel
Kirkland
Super tight screws to wall
Hi,
I am trying to remove one of the dinette bench on my 16RB, in order to get better access to water tank and wiring for an electrical project. I checked how the plywood seating/bench is attached to the body, basically it's 3 L brackets on top + L bar at the bottom. the 3 L brackets are screwed directly onto the wall, likely into the ribs judging by rivets aligned very closely. The screws are philips head ones, but very tight, I could not unscrew it with a hand screw driver, it's a very narrow place to put force on it, but I also felt if I try harder it would strip the screw head .
I do have power tools, 12v or 20v impact drivers, but I think they have even higher risk of striping the heads (I usually do torx and square head screws with impact)
It's also very hard to unscrew the plywood side of the screws, as limited clearance between the wood and top of the water tank.
Would appreicate it if anyone have some advice on this, thank you.
-Hovr
10-13-2020, 04:16 PM
2007 22' International CCD
Corona
Violence and power tools carefully applied...sometimes brute force is the only way remaining!
Philosophy is force it, if it breaks, it needed replacing anyway...what would Macgyver do?
Yup, I’m wearing my alma mater’s shirt today...
10-13-2020, 04:34 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Whack it with a Hand Impact Driver
If it breaks...drill it.
10-13-2020, 04:47 PM
2021 16' Caravel
Kirkland
Thanks folks, I am not worried about the screws, I am more worried about the aluminum wall/rib. I will see if I can get a ratchet that takes a hex driver bit that are short enough to unscrew the ones from plywood.
10-14-2020, 07:39 AM
2018 25' International
Slidell
, Louisiana
if you have or get a ratchet and hex bit, I use a small pry bar to add enough force to hold the bit into the screw slot.
10-14-2020, 07:59 AM
1995 25' Excella
xxxxx
, xxxxxx
I recently removed the door trim to tighten my door hinges. I couldn't remove the screws by hand even with good access. There was no doubt they were going to strip. A battery impact driver zipped them all out with no damage.
10-14-2020, 12:57 PM
2019 27' International
Rogers
, Arkansas
Bayou Brian Nailed it or should I say unscrewed it. Use plenty of downward force before turning.
10-14-2020, 01:53 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
You have infinite choices with a manual impact driver, the harder you tap it the more shock impulse you get.
Plus, you are turning it by hand when you hit it so your only using it to get it started and can tell instantly when it breaks free and continue removal by hand.
10-14-2020, 02:18 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
Be sure you have a good fitting Philips tip ( there is a difference) and use the impact driver. Hold it tight and square
10-14-2020, 07:16 PM
1968 20' Globetrotter
Montrose
Might also try an extension to get the impact further out for better control.
10-15-2020, 08:22 AM
2021 16' Caravel
Kirkland
Just want to give an update on this, I used a ratchet and a short hex bit and managed to unscrewed the ones into the plywood, after I removed the bench I was also able to unscrew the ones into the wall with much better access. Thanks for advice everyone!
