SunExplorer II Display
May be late to the party but had same issue on AS25 2018 Flying Cloud with SunExplorer II display going dark. Pulled unit out and when I disconnected the wire connector Aluminum shavings fell out of the connector. Cleaned out shavings reconnected and unit works fine. Additional note, on install the factory applied a strip of electric tape covering top section of pc board to prevent contact with Aluminum wall and shorting out unit. Check tape insure pc board has not worn thru and now making contact with Aluminum siding.
