Old 08-07-2022, 05:31 AM   #1
1972 29' Ambassador
WIGAN , England
Steps not staying up/working properly
I have a 1973 Airstream Ambassador 29ft, centre bath twin. It was built at the California plant.
My steps are not staying up or working as they should. They will drop a few inches and stay in that position. If I want to use the steps I have to pull them down by hand. The lever on the right hand side doesn’t seem to do anything.
The outriggers everything is attached to are sound and nothing moves there, so I believe it’s part of the mechanism??
Could anyone offer any help or advice please?
Thanks in advance,
Dean
Deano uk is offline   Reply With Quote
Old 08-07-2022, 06:31 AM   #2
turk123's Avatar
2019 30' Classic
Sunnyvale , California
Early on with my current trailer, I had a similar problem with my steps. At one point I thought my steps were bent. It worked that bad. We had other issues we needed to be fixed so I'm three hours from the factory so I took it in.
The service guys just hosed it down and then applied lots of silicon spray to the steps concentrating on all the joints and undercarriage mechanism. It all works just fine now. I revisit the lubrication of the steps two or three times a year to keep it functioning properly.
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 08-07-2022, 07:36 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Dean,
Can you take a few pics and post them showing the problem? Include a pic showing the steps deployed and then go under and look into the step outriggers. The outriggers might need a repair.
Pictures should help with suggestions.
Gary
GCinSC2 is offline   Reply With Quote
Old 08-07-2022, 02:19 PM   #4
1972 29' Ambassador
WIGAN , England
Thanks for the suggestion and sharing your own experience. I’ll give the lubrication a try!
Old 08-07-2022, 02:21 PM   #5
1972 29' Ambassador
WIGAN , England
Originally Posted by GCinSC2 View Post
Dean,
Gary
I will this week when I next go there and post them. The outriggers look as they should but I’d be grateful for your opinion when you see the photos. Thank you!
Old 08-12-2022, 10:25 AM   #6
1972 29' Ambassador
WIGAN , England
Dean,
Gary
From what I can see on looking at it closely today, it would help me if I cleaned the tracks where the steps slide, it need lubricating, the lever on the right hand side doesn’t work properly. The rollers don’t seem to correspond or work with the lever somehow?? That’s just my first thoughts anyway.
I couldn’t get a picture of them folded out, because I couldn’t get the steps down far enough to unfold them. The steps functioned the same when there was a subfloor and the outriggers seem very secure.
ID:	420861   Click image for larger version
ID:	420863   Click image for larger version
Steps not properly supported in the extended position chrisnancy Steps 10 11-24-2019 11:19 AM
Hot water heater not working properly kiddoc1 Plumbing - Systems & Fixtures 6 03-27-2014 05:37 PM
Humphrey gas light not working properly bmklawt LP Gas, Piping, Tanks & Regulators 6 12-05-2011 10:58 AM
New Water Heater Not Working Properly BobbyWhitit Water Heaters, Filters & Pumps 8 04-18-2010 02:10 PM
Water Pump Not Working Properly? 74SovereignInt. Water Heaters, Filters & Pumps 8 11-11-2002 01:44 PM
