Old 09-20-2020, 05:22 PM   #1
2017 19' Flying Cloud
2019 23' Flying Cloud
Evans , Georgia
Angry Stair Repair 2019 23 FC
I have a 2019 AS 23FB FC that has the factory stairs. There is long slot on each side of the underbody enclosure that bolts extend through to support the stair brackets and allow the assembly to swing out. On a recent trip, the right side bolt fell out making the stairs unusable. I inspected and found no visible means of re-installing the bolt. A call to Airstream tech confirmed that the belly pan has to be removed to install the bolt. I assume that includes drilling out rivets, etc. My first thought was why would Airstream make a design so difficult or at least install locknuts/thread locking to prevent the bolt from backing out? So, I made an appointment with the nearest dealer (90 miles) and wait a month. I would like to do the repair myself. Has anyone out there had this issue or know the repair procedure. Thanks..
kmhale is offline   Reply With Quote
Old 09-20-2020, 05:50 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
An emergency MacGyver repair...2013
I did not remove the BP.
I got a grade 5 full threaded bolt. Threaded a nut all the way down ground and filed the exposed threads off to lessen ware on the slot. Filed a better profile on the slot, used 243 Loctite. Installed it from the outside.
SFSG.👍
ID:	379125   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
ROBERT CROSS is online now   Reply With Quote
Old 09-20-2020, 06:24 PM   #3
Oh forgot to mention...remove the nut.🥴
Molly Ivins
Tahawus
Old 09-27-2020, 05:53 PM   #4
Evans , Georgia
Thanks for the response. I started to install the new bolt, but it turns out the right hand side belly pan was small and removable by drilling out rivets. It is roughly 12" x 12" with 4 rivets. I removed the pan, retrieved/installed the bolt, and riveted the pan in place. Also, I dremeled a slot in the end of the bolts to allow for screw driver tightening, then added a jam nut.
Stair light repair lsbrodsky Lights - Interior & Exterior 2 03-16-2020 02:31 PM
1968 Sovereign restoration / Missing Stair Catch tmwsiy 1965-1969 Sovereign 0 08-22-2013 08:16 AM
1965 Globetrotter stair repair help needed dzuroski 1965 - 1969 Globetrotter 0 12-04-2012 10:44 AM
stair and awning questions Hardenburgh General Repair Forum 3 04-17-2012 07:40 AM
Dry rot on the flooring above the stair ckeysor 1984 - 1989 Sovereign 6 09-26-2006 04:15 PM
