Old 09-22-2021, 09:16 PM   #1
San Diego , CA
spin welded sprayer
can i replace a spin welded sprayer with a glued one on my black water tank of my 2018 airstream interstate grand tour. mine cracked at the inlet fitting likely because it was overtightened when installed. thanks for your help
Astlo is offline   Reply With Quote
Old 09-23-2021, 07:52 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
First thing to do is figure out what the tank is made of. Likely it is ABS or HDPE. Since you have a spin welded fitting, it is likely a thermoplastic like HDPE, and not very much sticks to that.
There are a few threads on these forums that deal with tank repairs, try searching for "tank repair" and you should get some hits. I recall one respondent saying they found a glue that would adhere to HDPE.
If you have clear access to the broken fitting, you might try just cutting the broken piece off flush with the tank, and spin-welding a new one on top of it.
good luck!
Old 09-23-2021, 09:10 AM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I used similar product on a few strange jobs and it worked. Two part epoxy putty.
https://www.lowes.com/pd/Oatey-Fix-I...-Putty/3132883
Might be worth a try.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is online now   Reply With Quote
E-locker/Anti-spin Rear Axle Hans627 Tow Vehicles 7 05-18-2018 06:36 AM
There's no good way to spin this mehes General Motorhome Topics 44 01-30-2017 06:39 PM
Coleman fan humming no spin Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 14 08-14-2015 07:20 PM
Armstrong A/C Motor Spin Direction? inTransit Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-13-2015 03:25 PM
Was Avion Mfg a spin-off of Airstream? Fishskihike Our Community 4 11-21-2003 02:34 AM
