Old 03-16-2022, 11:40 AM   #1
2016 28' International
Annapolis , Maryland
Spare Parts
Hello,
I am curious; what spare parts do you keep on hand in case something breaks/emergency? I have a '16 signature.
Mark
super90ish is offline   Reply With Quote
Old 03-16-2022, 12:33 PM   #2
2016 27' Flying Cloud
Little rock , Arkansas
Water pump, dinosaur board, l&r brake assembly
Dtrentr is offline   Reply With Quote
Old 03-16-2022, 01:09 PM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Mark,
I carry some "stuff" to guard against the unknowns. But the most valuable other than tools and parts is taking some time to learn about the systems, water, 12VDC, 120VAC, fridge, water heater, propane and the furnace.
If you study up on these systems it can be a real plus if something acts up. A common example is the gas fired hot air furnace. It has a starting sequence and learning how to listen to this start up sequence is a big part of diagnosing and fixing.
Spares:
30A male plug end, PEX repair fittings assortment, some fuses and electrical fittings, good tool selection and more but it's a bit tailored to my rig.
Gary
GCinSC2 is offline   Reply With Quote
Old 03-16-2022, 01:35 PM   #4
Kevin245's Avatar
Spare Parts
We keep an assortment of plumbing fittings on hand, along with a spare set of wheel bearings and seals. Also a quality 12 volt compressor, various electrical splicing supplies, zip ties in assorted sizes, and roll of good quality duct tape.
William C. Swinney
Old 03-16-2022, 05:06 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Don't forget a spare fuse for the jack(hardest fuse to find quick).
Old 03-16-2022, 07:50 PM   #6
2017 25' International
West Lake Hills , Texas
  1. All the tapes...blue painter's, gray duct, aluminum duct, various special 3M, etc.
  2. I had carried a left and a right brake assembly but mine are newly installed so I'm winging it for now. Kind of exciting to be out there without spare brake assemblies.
  3. Extra u-bolts and lynch pins for the ProPride hitch
  4. DC fuses.
  5. Surge protector in case the EMS fries.
  6. Multiple lubricants, especially plumbers silicone for the toilet ball valve.
  7. Extra 30-amp power cord.
  8. Extra water hose.
  9. Well-stocked electrician's bag including various WAGO connectors.
  10. Cash...lots of cash. And a couple of credit cards with lots of unused credit.
On the list to carry in the future: Fridge board.
Fungus is offline   Reply With Quote
Spare, spare tire? jondrew55 On The Road... 6 01-03-2022 05:50 PM
Dang, why's my spare tire carrier hanging down? Darn, where's my spare tire? rhensley 2016 - Current Classic (all lengths) 0 10-18-2021 07:17 PM
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 05:13 AM
Creating a spare for the spare easyride Tires 0 06-10-2008 04:16 PM
Spare Parts/replacements lists Chuckles Mechanics Corner - Engines, Transmission & More... 2 08-14-2006 10:12 AM
