Old 05-13-2021, 03:00 PM   #1
2023 27' Globetrotter
Williamsburg , Virginia
So I have a Leak...
Last week while camping, I noticed a small leak coming from one of my freshwater hoses that routes out to the trailer on the street side over to the curb side. My rig is a 2019 FC 27 FBQ. The water is coming out of the rearward of two hoses, and starts anytime pressure is on the water system, whether water tank or city water. It drips at a very slow rate, maybe a drop a minute. I've looked at the area around the water pump on the inside, and as far as I can see with that access, everything is dry. I cannot determine from the provided fresh water diagram for a 27 what the source for this hose is. Any Ideas? Leaks don't fix themselves, but I'm at a loss as to how to find access to where this hose comes from. Thanks in advance.
ID:	395418   Click image for larger version
AgBullet is offline   Reply With Quote
Old 05-13-2021, 03:35 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
That looks like one of the propane lines. Perhaps the water is just finding it's way to where that propane line enters the trailer?
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-14-2021, 10:04 AM   #3
Not a propane line...it's a water hose, one of two that cross the trailer underneath.
Old 05-14-2021, 11:33 AM   #4
2019 30' Flying Cloud
Grass Lake , Michigan
Photo looks like the propane hose. Water lines are all PEX in newer trailers.
oldenavy is offline   Reply With Quote
Old 05-14-2021, 11:59 AM   #5
According to the owners manual diagram, there are two hoses (not PEX) that cross the trailer underneath. Pretty sure these are not propane. Otherwise, why would there be a leak?
Old 05-14-2021, 12:21 PM   #6
2014 27' FB International
Lewisville , Texas
Similar leak on this thread
https://www.airforums.com/forums/f44...lp-219534.html
NO NOIZE is offline   Reply With Quote
Old 05-14-2021, 12:27 PM   #7
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
Does not look like a pressurized water line. All water supply lines are PEX and not routed externally.
Maybe a black tank flush hose connection?!
panamerican is offline   Reply With Quote
Old 05-14-2021, 12:28 PM   #8
Lily&Me's Avatar
Normal , Illinois
I’m guessing you have already tried to follow them to where they connect to something, but that’s what I would do first.
I have had small leaks behind the toilet and under the sink that were simply connectors that had worked themselves slightly loose.
Good luck.
Maggie
Old 05-14-2021, 12:45 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I don't know where that goes... looks like a rubber hose going into the trailer, though the rubber 'gasket' screwed to the pan. Take a screwdriver and see if you can scratch a small spot.. to see if it is copper or plastic line. Remove the 'gasket' and look inside... post a picture of your investigation..
Propane lines run under the trailer so that if you get a propane leak on the supply lines, since propane is heavier than air, you have minimal chance of it getting inside the AS.
That line appears to be a LP line because the fitting looks like what you usually see on one... but, AS does make changes...
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-14-2021, 12:51 PM   #10
Originally Posted by NO NOIZE View Post
Thanks for this steer! It does sound like the leak is following a gas line (I had convinced myself it was water. My issue sounds exactly like the issue identified in the link. I'll try and follow up with the OP of that link.
Do I have a leak, or is it possible I have this much condensation pooling? febbraro Airstream Trailer Forums 9 01-05-2021 12:05 PM
A ponder - Would Have,Could Have ,Should Have Life is a Highway Towing, Tow Vehicles & Hitches 37 11-01-2019 07:55 AM
To have or not to have...vent covers??? Director Roof Vents, Skylights & Fans 2 10-21-2007 01:25 PM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
