Old 07-08-2022, 10:08 AM   #1
Displaced Beach Bum
beachbouy's Avatar
2016 30' International
Texas Airstream Harbor , Texas
Send a message via Skype™ to beachbouy
Smoke Coming from Ducted Air
Where would I look first for a problem? I'm stumped and just caught it and shut it down.
We drag Mitzi a 2016 International 30 w/Goodyear Endurance, Equalizer 1000, pulled by a 2018 GMC Sierra 1500 SLT 4x4, Crew Cab, 5.3L V8 ECOTEC3, 3.42 axle, 8 speed auto WBCCI #6111
beachbouy is offline   Reply With Quote
Old 07-08-2022, 10:12 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Was it smoke like from a fire or more like a fog?
If smoke, did it have any type of particular smell to it?
Richard
11018
richard5933 is offline   Reply With Quote
Old 07-08-2022, 10:13 AM   #3
Displaced Beach Bum
beachbouy's Avatar
smelled like smoke
Old 07-08-2022, 10:14 AM   #4
2022 27' Globetrotter
DALLAS , TX
Smoke? Or fog? Both look similar but smell different.
Fog isn't uncommon if the air in the trailer is humid and near the dew point.
In fact, a major function of air conditioning is to remove excess air via water condensing on the cold evaporator coils.
foobar is online now   Reply With Quote
Old 07-08-2022, 10:37 AM   #5
2017 25' Flying Cloud
Celina , Texas
Remove excess water.
2017 Ford F150 Lariat 3.5L EcoBoost w/Max Tow
FAA Certificated Remote (Drone) Pilot
Amateur Radio Extra Class N5EAS
Journeying America via the "Blue Highways"
-Be Curious, Not Judgemental…Walt Whitman-
Genebuilder is online now   Reply With Quote
Old 07-08-2022, 10:38 AM   #6
Celina , Texas
That’s why you have a condensate drain
Old 07-08-2022, 10:39 AM   #7
Celina , Texas
Certain smokes can be beneficial, even medicinal.
Old 07-08-2022, 11:34 AM   #8
1994 25' Excella
Originally Posted by beachbouy View Post
smelled like smoke
I guess I was hoping for something more specific - smoke from a wood/paper fire? smoke from an electrical fire? smoke from melting plastic? etc. Lots of diagnostic steps can be skipped if we know what was burning that resulted in the smoke being released.
If you don't know, then you might benefit from opening the intake vent where you can view into the underside of the a/c unit. Not sure exactly how to do that on your unit, so hopefully someone will chime in. At the basic level, you can pull your intake filters and use a flashlight to peer inside.
You're looking for signs of burned/discolored/melted plastic or wire insulation, or any other signs of overheating.
This would be my first step if you're sure that it was smoke resulting from something burning (or nearly burning.)
Richard
11018
Old 07-08-2022, 11:41 AM   #9
Displaced Beach Bum
beachbouy's Avatar
Angry
Found it! Typical quality factory work. Poor connection inside junction box shorting.
Will replace and clean up their messy crap.
Old 07-08-2022, 12:17 PM   #10
Celina , Texas
Sounds fishy. A short would have tripped a breaker. If it didnt, don"t pat yourself on the back yet. You have bidder issues lurking.
Old 07-08-2022, 12:19 PM   #11
Celina , Texas
bigger.
Unless you have an old style fuse box that has a penny inserted instead of a screw in fuse.
Old 07-08-2022, 12:49 PM   #12
1994 25' Excella
But a loose connection arcing wouldn't necessarily trip a breaker.
Richard
11018
Old 07-08-2022, 02:10 PM   #13
Celina , Texas
The electrical junction box in the AC does not penetrate into the air plenums. How would electrical smoke, acrid and easily identifiable, get into the air stream entering the trailer?
Old 07-08-2022, 02:31 PM   #14
Celina , Texas
Actually, an arc would trip a breaker. Arc fault, as well as ground fault interruption is in breakers required to be installed in RVs
Old 07-08-2022, 02:32 PM   #15
1994 25' Excella
I don't know the specific a/c unit we're talking about here in this example, but on my trailer the junction box (and accompanying circuit board) is right smack in the middle of the return air plenum. It's not air tight and if there were smoke in the junction box it would certainly be sucked into the air flow.
Richard
11018
Old 07-08-2022, 03:16 PM   #16
Celina , Texas
Yep. Different configurations. Lets go back to the beginning. What wire was arcing? How was it fixed?
Old 07-08-2022, 05:54 PM   #17
Escape Pod II
John Ware's Avatar
2018 22' Sport
2022 23' Flying Cloud
Orange , Texas
It's nearly impossible to diagnose a problem with minimal information. One can only guess or cite a probable cause.
JEWare
John Ware is offline   Reply With Quote
Old 07-08-2022, 08:15 PM   #18
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
A regular breaker won’t trip the arc will continue until the circuit overheats and fire results , and won’t trip until the circuit shorts .
Neither will a ground fault breaker trip .
Only an arc fault will trip at the first arc .
By the way if you have a old Hover or any brush type motor plugged into an arc fault circuit it will instantly trip the arc fault breaker when you turn it on .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 12:24 PM
Outside Smoke is coming inside thru the AC!!! VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 13 11-11-2012 02:40 PM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 02:43 PM
Smoke, Smoke Everywhere ncbambi 2008 Safari SE 14 07-25-2010 07:28 PM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 08:06 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
