Old 08-08-2020, 01:50 PM   #1
2020 30’ Globetrotter
Phoenix , Arizona
Slide out pantry won’t stay closed
When we parked our 2020 Globetrotter after a day of driving, I was surprised to find that the slideout (pullout) pantry drawer had, well, slid out and was open.
This is the tall cabinet with a spring-loaded button to open. After closing the drawer, I found that it could be pulled open without pushing the button.
When I looked at the button latch, it appears that it doesn’t quite reach the metal tab that is supposed to keep it from opening without the button being pushed in.
I wonder if anyone here has experienced this issue and can suggest a fix?
Thanks, as usual.
Mike
mkaiseraz is offline   Reply With Quote
Old 08-08-2020, 03:29 PM   #2
2009 25' FB Flying Cloud
Easton , Pennsylvania
Has the slide-out jumped out of its rails?
Hi, Mike,
Are you sure that the slide-out hasn't jumped off of its rails, as sliding shower doors sometimes do? If it has, this would make it hard for the latch to engage the tab on the frame.
Cheers!
Chuck
Thanks, as usual.
Mike
Chuck H is offline   Reply With Quote
Old 08-08-2020, 04:18 PM   #3
Phoenix , Arizona
the
Originally Posted by Chuck H View Post
Hi, Mike,
Cheers!
Chuck
Good question. Yes, I checked. The drawer slides easily and I can see it’s still in the rails.
Old 08-08-2020, 08:30 PM   #4
Burnside Bob's Avatar
1973 31' Sovereign
Mt Angel , Oregon
After reading your post I had to check my pantry door. AND my pantry latch wouldn't catch on the strike either. I could just pull it open.
What I discovered was that the latch assembly, which is in two pieces that thread together, had loosened enough that the latch rotated to where it no longer engaged the strike.
By turning the interior latch piece clockwise I was able to tighten it into the correct position for the latch to catch the strike.
Good as new. Well, maybe. We blame this on our trip to Chaco National Cultural Park in New Mexico--worst washboard ever.
If you don't find this to be the solution, has something fallen in the pantry space that prevents the pantry rack from sliding all the way in?
Burnside Bob
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 08-08-2020, 10:22 PM   #5
Phoenix , Arizona
Thanks, BB. I’ll have a look and see of the latch screw-in has loosened. Interesting observation.
Mike
Old 08-09-2020, 08:48 AM   #6
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
For a bit of Extra Insurance, we started using this tape on the 3 pantry doors and the medicine cabinet mirror. Works great. Easy to hand-tear. Leaves no residue.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 08-09-2020, 09:21 AM   #7
EricF's Avatar
2019 27' Globetrotter
Madison , Wisconsin
Thanks, as usual.
Mike
I had this problem and the microwave fell to the floor and broke. It was covered under warranty but they didn't fix the slide drawer. I found that the latch catch needed a small spacer between it and the wood to catch the latch better. I think I used a few layers of duct tape as a spacer and it worked like a charm.
2019 GT 27FBT 50 amp
2016 F-150 6.5' 3.5L Max Tow Crew Cab
Blue Ox Sway Pro
EricF is offline   Reply With Quote
Old 08-09-2020, 10:50 AM   #8
Phoenix , Arizona
Thanks to EricF and Piggy Bank. Both offer good advice.
Old 08-09-2020, 11:27 AM   #9
Mollysdad's Avatar
Suggestion 1. Why doesn't the latch latch? Is there some adjustment in the latch? Does the screw slots allow some more adjusting so the catch catches?
Suggestion 2. I heard how the microwave drawer in my unit could come open, so I made a prop consisting of a wood dowel with white rubber tips on each end.
It goes between the drawer and the opposing wall, about 26". I only use it while underway. (It works so well I have one to keep the microwave open. If I'm slightly off level the microwave drawer wants to close and that shuts off the power.)
Your floorplan might not allow this since the fridge(?) is across from the pantry.
Suggestion 3. A backup. A travel latch of some kind. Even the hidden spring latch like we have on some cabinets. A 10lb latch is pretty stout to pull open.
Don't just slap on some hardware store bolt and ruin the esthetics.
Suggestion 4. Magnets. Amazon sells some very strong magnets. Perhaps mount a metal bracket inside the cabinet and a magnet on the door, so when closed they meet!
Old 08-09-2020, 11:36 AM   #10
demijac
2014 27' FB Classic
Livingston , Texas
Send a message via Skype™ to demijac
Insurance
We’ve had this problem ‘off and on’ enough times over the years that we now use an adjustable shower rod that wedges between the closet door across the hallway and the pantry door. Works like a charm.
demijac is offline   Reply With Quote
Old 08-09-2020, 04:13 PM   #11
Phoenix , Arizona
Good suggestions. My COMMENTS are below . . .
MY COMMENT: No adjustments per se, but as someone else suggested, I could look into putting a spacer and longer screws--to lower the plate the latch is supposed to grab onto.
MY COMMENT: Yeah, the drawer/pantry I'm talking about is the same one your microwave is on. We chose the option where the microwave is under the cooktop, to give us more storage in the pantry. A dowell, or spring-loaded shower curtain rod, like someone else suggested, could be used to keep the drawer closed during transit.
MY COMMENT: Not sure what kind of latch you're referring to.
MY COMMENT: I like it. Might look into this one, too. Thank you.
Old 08-09-2020, 04:14 PM   #12
Phoenix , Arizona
Good thinking. Thank you.
Old 08-09-2020, 04:23 PM   #13
Josephine517's Avatar
2017 23' Flying Cloud
Beavercreek , Ohio
ID:	375358Click image for larger version
Josephine517 is offline   Reply With Quote
Old 08-09-2020, 04:26 PM   #14
Beavercreek , Ohio
Originally Posted by Josephine517 View Post
My fix. Wedges to lock the drawer in place as it closes. Allows the latch to hold. Also added another locking latch for added security. Haven’t had a problem with the pantry since.
Old 08-09-2020, 04:36 PM   #15
Phoenix , Arizona
Nicely done, Josephine517. And thanks for the photos.
Old 08-09-2020, 06:20 PM   #16
2020 23' Globetrotter
Dorset , Vermont
We had the same problem with our 2020 globetrotter… the cause was the pantry door would bow especially during humid weather so it couldn’t close properly. Oddly without humidity the door was fine. We took a picture of the bowed door and our dealer worked with airstream and they sent/installed a replacement door. It has been fine ever since.
226TuckL is offline   Reply With Quote
Old 08-09-2020, 09:06 PM   #17
Phoenix , Arizona
Thanks, 226TuckL. I'll have a side look at our door. If that's the problem, I'll take a photo and see how we make out. Worst case, I'll ask you to send us your photo.
Mike
Sliding pantry slider replacement help? (The narrow, wire rack style pantry) brad1 Cabinets, Counter Tops & Furnishings 1 08-09-2019 03:55 PM
Slide Out Pantry Slide Hardware jhohe General Repair Forum 0 10-12-2015 03:08 PM
Pull Out Pantry Baskets Don't Stay In Place murreywalker General Repair Forum 9 09-27-2011 02:49 PM
Storage door won't stay closed possummamma Exterior Storage Compartments & Access Doors 3 08-04-2009 06:24 AM
Medicine cabinet door won't stay closed jordandvm Cabinets, Counter Tops & Furnishings 10 10-03-2004 08:24 AM
