Old 03-06-2020, 09:05 PM   #1
2019 25' Globetrotter
Denton , Texas
Shower drain leaking or clogged?
2019 25ft globetrotter.
Underneath the RVClick image for larger version
ID:	362774Click image for larger version
The rubber hose/tubing has water slowly dripping but the flooring next to my shower is damp to the touch.
Could there be a clogged drain that is leaking or does anyone else have ideas?
Rak187 is offline   Reply With Quote
Old 03-07-2020, 05:52 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Rubber hose shot, is that from under your trailer? That floor leak looks like it is coming from inside your trailer.
Have you checked fitting connections in the area? You can remove all the access panels in the trailer and give a peak. Looks for drips or try to track where the floor is most damp.
Worst case, are you still under warranty?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 03-08-2020, 02:58 PM   #3
Denton , Texas
[ATTACH]Click image for larger version
So these are the best picks I could take.
I turned the water off a couple days ago and put fans, used the furnace vent and had three containers of Damp Rid in the area so it is dry.
I’ve let the shower in for about 20 minutes. Not seeing any leaks or drips.
Old 03-08-2020, 03:03 PM   #4
Denton , Texas
Sorry if it’s a duplicate.
This is the best picture I could get.
It looks like where that hose is is where the most water damage to the board is.
Old 03-08-2020, 03:32 PM   #5
2002 19' Bambi
Lafayette , California
You are right. Where the water leaked seems to be concentrated around the place where the rubber hose goes down through the plywood (I did have to turn the pictures right side up!). There is no indication that the drain or P-trap have leaked. If the hose carries water, I would check to see if it is damaged in passing through the plywood.
You seem to have recognized the problem in time, because the plywood shows no sign of delaminating. If you can find the source of the leak, there should be no permanent structural damage.
Tim
Tim A. is offline   Reply With Quote
Old 03-08-2020, 04:07 PM   #6
2018 30' Classic
Water follows the path of least resistance too. If you can’t find the source there then it may be up stream a bit more?
You may have to turn the water back on with multiple sources running to try and get a solid visual.
Let us know how we can help
BigSxyWhtGuy
Shower/Kitchen Sink Drain clogged glistok Land Yacht/Legacy Motorhomes 3 02-21-2020 03:56 PM
Clogged shower drain Arnoldjeff 2009-2015 Flying Cloud 6 07-20-2019 07:19 AM
Clogged shower drain Jamesbford 2016 - Current Flying Cloud 3 10-13-2018 10:35 AM
Clogged Shower Drain on MH comprose Plumbing - Systems & Fixtures 4 09-18-2015 04:05 PM
Help! Yucky clogged shower drain Blu_Hwy_Lady Waste Systems, Tanks & Totes 25 05-10-2006 02:07 PM
