Old 06-16-2021, 03:11 PM   #1
2019 25' Flying Cloud
Maple Ridge , British Columbia
Shower door water deflector??
Hi everyone. is there something to use so that the water running down my glass shower door get deflected into the shower and not in the shower door track, or my floor and under the shower?
the one that came with my NEW 2019 Airstream
FC pretty much disintegrated after 3 months...
thanks
MrScratch is offline   Reply With Quote
Old 06-16-2021, 04:16 PM   #2
2014 27' FB International
Lewisville , Texas
Use This Fix
There are multiple postings of the plastic edging that inserts into the bottom of the shower door from the factory breaking off. Some have had it replaced under warranty several times with the same result.
I found a ten dollar fix at Amazon, https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
This edging is flexible, applies with the included peel and stick tape and installs in five minutes. The roll is eight feet long so you have enough to do the door three or four times.
Cut a piece longer then you need and place it in the sun and warm it up and straighten it out before applying. You can cut it with household scissors, clean the bottom of the shower door frame with alcohol and apply to the bottom inch of the door frame so it guides the water away from the bottom gap back into the shower.
To be clear, this does not snap into the bottom of the door like OEM, it sticks to the bottom frame facing into the shower. The "L" shape deflects the water back into the shower floor rather than flowing into the bottom sill / "shower door track".
Another thing you can do is add some sealer to the sides of the bottom sill / "shower door track" to additionally direct water flow away from the outside.
I did this on my 2014 27FB Serenity five years ago and the same piece is still on there and it does not leak any water outside the shower door at all.
Good luck
NO NOIZE is offline   Reply With Quote
Old 06-16-2021, 04:35 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Like many I leave mine off / never replaced it.
It would "sweep" water into the hallway whenever I opened the door. I have had no problems since ditching it / going bare bones.
wulfraat is offline   Reply With Quote
Old 06-16-2021, 05:44 PM   #4
Lewisville , Texas
Link Problem?
I checked back on this thread to see how things were progressing and discovered the link to the product I suggested on Amazon does not work on my phone, but it does on my laptop?
Here it is again: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I don't know how this works?
Old 06-16-2021, 06:08 PM   #5
2019 30' International
Pennsylvania , Pennsylvania
We have a '19 International and the last time that flimsy flapper failed we decided to forget about replacing it. No water on floor, no worries.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 06-16-2021, 10:50 PM   #6
thank you!
perfect!!
Old 06-16-2021, 10:51 PM   #7
Good luck
thank you!!!
i figured maybe there was something like that
Old 06-17-2021, 03:46 PM   #8
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
One fix might be to caulk in the bottom shower door track real good and drill some drain holes toward the inside of the shower. Clean of the burrs. Automatic drain!
guskmg
Wanted Curb Side Rock deflector for Late Model 19' Bambi pkm123 Airstream Classifieds 0 04-11-2016 10:01 PM
How to replace Fridge air deflector? Jim J Roof 1 10-31-2015 10:44 AM
Bug deflector paullovern Sprinter and B-van Forum 9 06-26-2014 05:43 PM
Retracting rock deflector?? FBC72 Rock Guards, Segment & Window Protectors 4 03-22-2007 09:21 PM
Anyone use an Air Deflector? flyfisher Our Community 12 02-19-2004 07:42 PM
