Old 07-05-2018, 07:41 AM   #1
Springville , Alabama
Should there be a gasket on side storage compartment door?
I have had my 2005 25' Safari for a while now, but just noticed there is a notch that runs along the entire perimeter of the storage compartment doors. It looks like it is designed to insert a rubber strip/gasket or piece of trim into the notch, but neither door has one, so I assume it is not designed to hold a gasket/trim, but to simply compress when you lock the door with the latch so it seals against the gasket in place on the door opening on the trailer.
I could not find an image of a compartment door at the AS parts supply stores to check, but would like to verify if a gasket is needed on the door if someone could set me straight.
driftwood1 is offline   Reply With Quote
Old 07-05-2018, 08:32 AM   #2
2016 26' Flying Cloud
Southlake , Texas
Yes, they should have gaskets.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 07-05-2018, 09:39 AM   #3
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
Hi. There are gaskets on the compartment frame, but no gaskets in the notch or seam that runs around the perimeter of the door itself, as you describe. Joe
jayseejay is offline   Reply With Quote
Old 07-05-2018, 09:48 AM   #4
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I used a double seal strip with adhesive backing and ran it around between the door and the frame. It makes a great seal.
I think its called gap blocker weather-stripping seal.
Steamy1 is offline   Reply With Quote
Old 07-05-2018, 12:40 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
No gasket on ours...👍
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 07-06-2018, 09:10 AM   #6
Thanks all, will leave it as it is, looks like it is designed that way. The gap between the two sides of the door panel must be designed to allow some compression when locked against the gaskets on the frame.
Old 07-06-2018, 09:34 PM   #7
Box Elder (formerly of Center Moriches, NY) , South Dakota
Only if you want to keep water out.....
NY24 is offline   Reply With Quote
Old 08-04-2021, 06:22 PM   #8
Flathead1984's Avatar
2020 25' Flying Cloud
lake Wales , Florida
My inside gaskets pull off the interior aluminum. Do I really need them?
e
Flathead1984 is offline   Reply With Quote
Side compartment door screws. sonoftol Ribs, Skins & Rivets 0 04-26-2015 07:02 PM
Is there a gasket/seal for a screen door? seismicfish Doors & Locks 8 03-12-2014 08:55 AM
Port Side Compartment Door Quince General Repair Forum 1 06-20-2013 09:56 PM
leak in curb side rear storage compartment,1999safari 25 ft. samf3355 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-19-2010 01:51 PM
