Old 05-01-2020, 07:40 AM   #1
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
Settee Dimensions?
Okay I know this can be a very subjective question. However I am looking for general guidelines .
I want to make a U shape settee (see drawing) Just wondering the average height of base from floor? How wide are the benches and how thick are the cushions? Even though I have a drop down pedestal I am not making this into an extra bed.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 05-01-2020, 11:10 AM   #2
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
Denver , Colorado
If you've got a drop down pedestal, it's able to be a bed whether you like it or not. ;-) (and at some point, whether you plan to or not, it will probably get used for one)
When I built my first dinette I made the mistake of not taking into account the depth and height of a typical cooler or storage container. When I was finished, my bench storage compartments were one inch shy of being able to hold my cooler (which I hadn't thought about putting in there while I was planning the design). Doh! Missed it by THAT much!
If you're building it as storage, the interior dimension may be more important than "typical height/depth" in the long run.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 05-01-2020, 11:39 AM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 21
Based on my experience with the one I built here are my thoughts:
As Kidjedi mentioned account for storage/mechanical underneath (if feasible). I had to offset my banquette towards the curb side 4" to account for the depth of the water heater underneath the seating on the street side. Height was close.
Thickness of your materials are accounted for in your storage area. I was using aluminum so it was minimal.
The seat bottom has to account for sitting and the back foam thickness. I'd suggest up to 18" of actual seating depth. I used my dining room chairs as a model and found the seating depth of 14" wasn't comfortable, couldn't slouch, had to sit upright
The height of the seat back was limited due to window ledge (about 8") on sides, 12" on front window. The 8" hits the wrong spot on my back if I lean back.
Square corners may be more practical than curved. If you want to sit sideways and use it for a lounge chair. I curved mine and sometimes wish I could stretch out.
Name:	banquette street side rear frame 2.jpg
ID:	366975 Click image for larger version
Name:	Banquette with cushions 2.jpg
If your table top will lower for a bed then size is dictated for you. I offset that a little by having a pedestal that allows the top to slide side to side and rotate (had to order out of France). See my thread for details.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 05-01-2020, 12:28 PM   #4
kidjedi's Avatar
1972 25' Tradewind
Denver , Colorado
Originally Posted by 57Vintage View Post
Nice!!! I LOVE the aluminum framing!
BeahmStream.com
Old 05-01-2020, 08:56 PM   #5
57Vintage's Avatar
1958 26' Overlander
Images: 21
Thanks I had purchased the tools for sheet metal work and wanted to see how it would work to maximize storage and save weight.
Name:	Banquette Frame test fit.jpg
Harold & Rebecca
Our thread:
Old 05-02-2020, 12:04 PM   #6
kidjedi's Avatar
1972 25' Tradewind
Denver , Colorado
Wow! That looks great. What thickness and "type" did you use for the sheet?
You didn't by any chance weight the materials did you? I know that's not likely, but I'd love to know how much weight this saved compared to timber framing and sheet. I'm all about building light (I cringe when I see tile and marble counters installed in "high dollar" builds).
BeahmStream.com
Old 05-02-2020, 05:35 PM   #7
57Vintage's Avatar
1958 26' Overlander
Images: 21
The seats are mainly 1" square tubing as vertical supports (.125 wall) and 1" angle (.063 thick) since a number of pieces are curved with Shrinker and Stretcher machines to curve the pieces of angle. Some straight sections on the top front of the seat bottom are .125 1" angle as this is the lip that supports the table top for making the bed. There are two pieces of 1X2 aluminum tubing to support the seat bottom on the two curved segments
https://www.eastwood.com/shrinker-st...caAr4vEALw_wcB
Seat backs are .032 alclad and the seat bottoms are .050 aluminum sheets with 3/4" angle (1/8" thick) riveted in the middle on the bottom to lessen bowing and center in the frame as they are removable to access mechanical/storage.
The seat fronts are architectural aluminum sheets I bought as surplus from a tiny house builder. It's a little stiffer than .032, but I never measured it because it has a thick plastic coating to protect the finish.
I never weighed it but it is really light. It breaks down into six pieces so its manageable to get through the door.
A number of pieces are welded to together, but a lot are just bolted together with 8/32 machine screws and rivnuts.
Harold & Rebecca
Our thread:
Old 05-02-2020, 05:50 PM   #8
kidjedi's Avatar
1972 25' Tradewind
Denver , Colorado
Rather than continue highjacking this thread , I'll take the aluminum framing conversation over to 57vintage's thread (https://www.airforums.com/forums/f97...er-172124.html)!
BeahmStream.com
Removing settee on 2019 25RB SagaCapt General Interior Topics 1 07-25-2019 12:06 PM
For 1986 325 Motorhome, ALL NEW settee, dinette cushions, drapes and blinds Olympiaguy Airstream Classifieds 0 07-22-2018 06:27 PM
Old Style Sofa Vs New Style settee Opinions Needed Jim Clark General Interior Topics 3 01-23-2013 02:53 PM
Settee in a 310 Chuckles Classic Motorhomes 13 03-12-2009 04:43 AM
Cushion Dimensions, Front Sofa Alan and Julie General Interior Topics 2 08-05-2002 02:14 PM
