i have a openings i want to seal in the AS. I read that someone mentioned REDGAURD as a good solution.
i bought a 1 gal can, along with the corresponding 6" wide pink role of waterproofing membrane. I also got you mold proof nylon screen used to stop cracking
it's not warm enough for the AS yet.
but i tested in my garage, where spring water has found a crack and is flooding the floor.
i filled the hole.
a thin layer of REG guard.
nylon mesh over the crack
red guard membrane on top
then cover with a thin layer of red guard again.
starts to dry in 6 hours
dries rock hard with 72 hours
goes on in bubble gum pink
turns to fire truck red when dried
so far i am very happy with the easy application and results
i own no stock or get any kickback. just a happy user sharing what works
