08-25-2016, 11:30 PM
2016 26' Flying Cloud
Southlake
Sealing hole in floor in 26u
I was cleaning out the compartment where the inverter, subwoofer and other miscellaneous items are located under the dinette. I noticed that I can see the ground when looking through the hole in the floor where several wires go underneath the trailer. What can I use to seal the hole that will be easy to get out if I ever need to run a wire through the hole. I first thought of silicone or spray foam insulation but those are both tough to deal with if you need to run something else through the hole. It doesn't look like any attempt was made to seal the hole by AS.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
08-26-2016, 05:40 AM
2016 23' International
Centennial
As new as your Airstream is, I wonder if you shouldn't be taking it in for a warranty claim to get the hole repaired?
Steve "Centennial Man"
08-26-2016, 06:08 AM
2012 30' Classic
Wildwood
I agree, take it back to the dealer. If you can see the ground, the mice can see in.
08-26-2016, 06:27 AM
2014 25' FB Flying Cloud
LaMarque
Just seal hole with great stuff foam. That's all the dealer is going to do. Save yourself the hassle of trying to get it into a dealership.
Sent from my iPhone using Airstream Forums silver bp
08-26-2016, 07:16 AM
2006 23' Safari SE
Biloxi
, Mississippi
I use silver metal HVAC tape to close off holes as I find them.
MICHAEL
08-26-2016, 07:44 AM
2014 25' Flying Cloud
Cuddebackville
, New York
Butyl tape works well. You can fill the hole and it will stay pliable.
2019 Ford Expedition Platinum
08-26-2016, 08:41 AM
2003 22' International
South Bend
, Indiana
Great Foam with pest control. It's amazing all the holes in an airstream that critter can get through.
08-26-2016, 12:47 PM
London
Same hole on my 26U. No big deal! I just stuffed some stainless steel wool [scouring pad] around the wires to fill the gaps.
You're a long time underground!
08-26-2016, 01:30 PM
2013 30' Classic
Greenwood
, Mississippi
00 (double aught) steel wool...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
08-26-2016, 03:19 PM
2007 22' International CCD
Corona
Regular steel wool will turn into total rust in no time. Go with stainless...
Sent from my pocket Internet using Airstream Forums
08-26-2016, 08:30 PM
Southlake
I went the easy route and used spray foam. I just hope I don't need to dig it out in the future. I know that mice like to eat the foam so I put a bait station in the compartment and will check it from time to time.
Equalizer Hitch
08-26-2016, 08:49 PM
, At Large
For those using steel wool, remember steel is a great conductor of electricity, and y'all are packing it around electrical wires. Just sayin'...
08-27-2016, 08:02 AM
Punta Gorda, Florida
Sealing hole in floor 26u
I'm a newbe to travel to tin can living. I have a 2016 FC 26u and your post got my attention. I thought the inverter was part of the electrical panel on the floor opposite the bath room. My dinette area has no openings where I could look into. I'm confused.
08-27-2016, 09:27 PM
South Bend
, Indiana
The converter is the bottom part of your power panel. There located various place depending on model and layout.
08-28-2016, 08:31 AM
I'm still confused. the 26u I was told is a new FC model and the only difference is either queen or twin beds. Walt
Southlake
If you take the cushions off the dinette, there are 3 areas: on the street side is the inverter, subwoofer, and miscellaneous gizmos. On the curb side is a large empty compartment. In the center, is a small compartment with a hinged lid.
Equalizer Hitch
08-28-2016, 08:39 AM
Southlake
I almost bought the insect proof foam but I am more worried about mice and rats.
Equalizer Hitch
08-28-2016, 08:51 AM
2013 30' Classic
Greenwood
, Mississippi
Seems like the foam would keep mice out, too...
TAC #MS-10
Airforums #70955
08-28-2016, 09:25 AM
London
Lift up the dinette cushion on the road side, then lift up the cubby hole cover and you'll be able to see the road below.
08-28-2016, 11:21 AM
The hole
I'll check it out. I'm grateful for all advice on the Forum. Thanks
