Old 12-23-2016, 03:12 PM   #1
1977 25' Tradewind
Durango , Colorado
Seal around the front door on a 1977 Land Yacht
I have a 1977 Land Yacht and the seal around the door (on the trailer side not the door side) is old and compacted. I am getting water leakage in the trailer because there is a gap. I recently replaced the gasket around the door but I didn't use the "Airstream" gasket. Now I am wondering if I should either replace the gasket on the door side with an Airstream gasket, replace the trailer side gasket, or replace both. Thoughts?
Campana5 is offline   Reply With Quote
Old 01-02-2017, 09:57 AM   #2
1975 31' Sovereign
St. George , Ontario
My 75 Soverign Land Yacht has door sealing issues. The curvature of the door did not match the trailer, the top of the door was 1/2" away from the trailer with the deadbolt secured. I could see daylight from inside and had water running down the screen when it was raining. So far my repairs are as follows:
1. Removed, the entry light from above the door, polished and rebuilt the unit with LED bulbs and new lexan lense.
2. Removed the over door trim, cleaned and polished.
3. Reinstalled trim and light with new sealant.
4. Opened the door 1 1/2" and placed an 8" length of 2"x2" between the door and frame at the latch location.
5. Parked my truck 2' from AS with the tire in line with the door.
6. Cut a piece of 2"x2" to wedge between the tire and bottom corner of the door.
7. While standing on the bed of the truck applied firm pressure against the top of the door, bending the door back towards the trailer.
8. Removed the 2"x2"s and checked the gap.
9. Repeated step 7&8 until the door closed flush.
All I have left to do now is replace the door seal once the weather warms up.
Eddie J is offline   Reply With Quote
Old 01-03-2017, 12:50 PM   #3
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Should it be noted to be easy when applying pressure on the door to avoid a cracked door frame?
Cyquest is offline   Reply With Quote
Old 01-03-2017, 02:35 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The 77 Airstream does not have the Cast Aluminum Door Frame as on the late 60's and early 70's door frames and can be reformed much easier as they are extruded aluminum frames. Removal of the inner skin eases re-contouring.
Land Yacht door and hatch seal replacement source Bella123 Land Yacht/Legacy Motorhomes 5 07-21-2017 02:08 PM
Polishing... When or what stage do you use the Tempro to seal around windows Shawnna Cleaning, Stripping & Polishing 8 08-29-2014 11:45 PM
Front door seal Mike Minegar Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 10 09-15-2013 09:29 AM
What is this paper seal around my windows and why is it starting to come out?? spoonbl Windows & Screens 10 05-14-2013 05:34 PM
1977 land yacht 31 vs 1977 argosy minuet 20 joe77 General Interior Topics 3 06-30-2009 08:51 PM
