Old 04-23-2020, 09:14 AM   #1
2009 19' International
lynn , Massachusetts
Screen door hinge Buck and Pop rivets?
Anyone know exact specifications for these on the screen door latch. I am replacing the main door hinge and can see no info posted on changing the hinge related to the screen door. The main door hinge comes with the hinge point to attach the screen door. The Buck rivets look bigger than the general exterior panel rivets.
Bosairstmer is offline   Reply With Quote
Old 06-20-2020, 06:56 PM   #2
1976 24' Argosy 24
White Haven , Pennsylvania
Bump. I too need to know. My screen door hinge rivets are stretched and I need to reset the screen door, by drilling out all the rivets and redoing them.
Has anyone found a suitable replacement for the 3 bucked rivets on each hinge?
Thanks, George
Gkiesel is offline   Reply With Quote
Old 06-30-2020, 09:12 AM   #3
1971 31' Sovereign
1973 29' Ambassador
Palm Desert , California
I need this info too. I have a cracked hinge and I need to install the replacement.
A 5/32 solid rivet fits in the hole of the new hinge but the rivet head is bigger than the rivets used on the body. No info in the service manual.
A little Googling and I think they are 5/32 Brazier head rivets. McMaster has them for $10 for a pkg of 250. I'm ordering a pkg. and if they are correct I can send some to you guys.
CaCraig is offline   Reply With Quote
Old 06-30-2020, 10:09 AM   #4
pjshier's Avatar
2017 27' International
Wasilla , Alaska
the dealer should know
We replaced the screen door due to damage from an attempted break-in while in remote storage. The dealer supplied all the parts, including the correct rivets. Because there is no Airstream dealer in AK, and I was suspicious of some dodgy answers given by SOB shops, I found an aircraft repair outfit that spoke fluent "rivet" for the work. They reported that the dealer-supplied parts worked great.
2017 Int'l Serenity 27FB
2017 F350 oil burner
pjshier is offline   Reply With Quote
Old 07-03-2020, 09:06 AM   #5
1971 31' Sovereign
1973 29' Ambassador
The rivets I got look to be correct. Message me if you need some.
Old 07-04-2020, 06:29 AM   #6
AFTER TAXES's Avatar
1964 22' Safari
1993 25' Excella
Flagler Beach , Florida
Images: 14
where do I buy buck rivets, and is there a special tool in install.?
thx
AFTER TAXES is offline   Reply With Quote
Old 07-22-2020, 08:41 PM   #7
1972 23' Safari
Palo Cedro , California
Are the rivets you refer to for your '71? Our screen door fell off our '72 Safari and we need to rivet it onto the hinge? Our original manual says to use 5/32" but not a specific type of rivet. The only mention of a specific kind of rivet in the book is the Olympic rivet. I don't know the difference between a buck rivet, a brazier head rivet and the Olympic rivet. HELP!!!!
CHFadm is offline   Reply With Quote
Old 08-01-2020, 07:33 AM   #8
1971 31' Sovereign
1973 29' Ambassador
You can buy buck rivets from VIntage Trailer Supply. Thatís where I got mine from.
The screen door on my 73 uses 3 buck rivets and 3 pop rivets. The pop rivets arenít standard head pop rivets. They have a bigger head.
Old 08-02-2020, 05:42 PM   #9
1976 24' Argosy 24
Yup. They're called Button Head Rivets around here
Pop Goes the Rivet or Missing interior pop rivets 22FB Msherw 2005 and newer - Bambi all models 46 02-14-2019 03:57 PM
Can I use a pop rivet in place of a 2 or 3 buck rivets? jackvosney Exterior Restoration Forum 7 10-01-2018 12:52 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
