Old 03-26-2020, 05:04 PM   #1
2019 28' Flying Cloud
Dripping Springs , Texas
Safe to drill into wheel wells? (Mud flaps)
Hi,
I'm planning a DIY mud flap installation. I see several people have created a bracket that in turn has been screwed or riveted to the existing aluminum strip at the back of the wheel well.
But - I could make the installation a lot more sturdy if I put a few screws through the flap into the back of the wheel well as well.
What's behind it? We have a 'twin' model so our beds are near the wheels but there's about a 6" space between the foot of the bed and the nearest interior wall.
Kalashnikov is offline   Reply With Quote
Old 03-27-2020, 12:09 PM   #2
Some new information: I will be using 2" screws that came with my flaps, 4 per side. Brand is DeWalt, from Costco.
Old 03-27-2020, 12:36 PM   #3
Mollysdad's Avatar
Make sure you don't drill into the shower pan.
Old 03-27-2020, 12:46 PM   #4
So if I drill toward the "back" of the wheel well I should be safe? Shower presumably is "up"
Old Yesterday, 07:13 AM   #5
Well this thread was inconclusive but I did it anyway:
https://www.airforums.com/forums/f44...ml#post2345505
Old Yesterday, 07:18 AM   #6
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Hey! When you take a shower now it will clean your mudflap!
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Our Google images and chat: https://photos.app.goo.gl/CMQbpNXQwapMnj8t9
turk123 is offline   Reply With Quote
Old Yesterday, 07:50 AM   #7
I really hope you're joking Those screws are located below the top of the frame. Ugh.
[I went inside the camper to look]
*whew*, no holes in shower!
Old Yesterday, 08:16 AM   #8
Mollysdad's Avatar
Good job!
From a past thread, the guy presumably used a bracket because his flaps extended outside the wheel well a bit.
So the flaps mounted on an arm and the arm mounted as yours.
I think it's wise to use mud flaps to protect the tank drain controls, as in your photo!
Old Yesterday, 08:23 AM   #9
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Yep I did the same type set up. I used the existing rivet holes to mount mine.
Your look great. Nicely done!
ID:	364214   Click image for larger version
ID:	364216   Click image for larger version
ID:	364219   Click image for larger version
Old Yesterday, 08:27 AM   #10
GMFL - I actually used your design for inspiration!
Mud flaps on a AS? AirHog Rock Guards, Segment & Window Protectors 8 04-29-2005 11:42 AM
Mud flaps on a AS? AirHog 2004 Safari 0 04-05-2004 07:07 PM
Roadwing removable mud flaps Kistler Our Community 4 03-20-2003 04:39 AM
Mud flaps on an A/S Silvertwinkie Our Community 8 03-10-2003 06:29 AM
Mud flaps on an A/S MH ALANSD Airstream Motorhome Forums 3 03-10-2003 05:58 AM
