Old 05-30-2020, 01:08 PM   #1
FrankM
2015 25' FB Flying Cloud
Lake Charles , Louisiana
Running/tail lights
The running and tail lights arenít coming on when plugged into tow vehicle. Brake lights , brakes, and blinker works. Tried two different tow vehicles, same results.
3fpm is offline   Reply With Quote
Old 05-30-2020, 01:50 PM   #2
moosetags's Avatar
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
The first thing I would try is taking a small nail file and clean the contacts in the Airstream's umbilical. Then you can test the running by taking a 10+ amp large plastic automotive fuse and stick it in the two contacts in either side of the key on the umbilical. The running lights should light.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
No running lights, brake lights or trailer lights work from tow vehicle RichHog 1969 - 1973 Safari 42 05-02-2019 08:42 PM
All exterior lights, brakes,tail lights, position lights. Lkjdude 2009-2015 Flying Cloud 12 10-04-2016 11:05 AM
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 10:31 AM
Tail, running, clearance lights not working dufferin Lights - Interior & Exterior 14 07-09-2007 02:53 PM
Wiring tail & running lights JimC Electrical - Systems, Generators, Batteries & Solar 4 04-14-2003 01:38 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
