Old 05-02-2021, 07:51 PM   #1
2012 25' FB Flying Cloud
Portland , Oregon
Rivets Popping
I have a 2012 Flying Cloud. Towed 48k miles. Is it normal for rivets to still pop?
I added stiffer 10 ply Goodyear ST225/75R-15/10 tires and used them 5,000 miles. 4 rivets popped - seems excessive based on my experience. Thinking about trading in the tires.
Hophead is offline   Reply With Quote
Old 05-02-2021, 08:02 PM   #2
2015 25' Flying Cloud
Tucson , Arizona
If this is a new phenomenon since you changed tires, your tire pressure might be too high. We have the same tires and run them at 65 PSI. What are you running yours at?
McStreamy_ is offline   Reply With Quote
Old 05-02-2021, 09:43 PM   #3
dropped rivet in grass
2019 23' Flying Cloud
Tarzan , Texas
The first thing that came to mind was "what's the tire pressure?".
Tall Grass is offline   Reply With Quote
Old 05-02-2021, 09:59 PM   #4
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Likely tire pressure. When I changed out to 16" Michelin's I started out at 75lbs. In the first 2 days of travel, I popped 4 rivets. Lowered the pressure to 65lbs and have not popped a rivet since.
thewarden is offline   Reply With Quote
Old 05-03-2021, 01:11 PM   #5
2016 30' Classic
Houston , Texas
I like the 'tire pressure' reason for rivets popping. Seems after any long trip, I have 2-4 rivets to replace. I have assumed that the normal giggling of the rig easily causes a relatively thin rivet to get sheared off. No big deal, easy to self-replace.
dhroberts is offline   Reply With Quote
Old 05-03-2021, 01:38 PM   #6
2009 34' Panamerica
2005 28' Classic
Still , in the thick of it
All my trailers post 19' have been 10 ply "E" rated tires. I have yet to pop any rivets. I agree, tire pressure and you might also consider adding these too:
https://www.centramatic.com/wheel-ba...pe=Trailers-RV
panamerican is offline   Reply With Quote
Old 05-09-2021, 11:04 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
My experience has been to replace any rivets that have popped. I have not had any rivets pop again after I replaced them.
Airstream service tech predicted this when I asked him about popped rivets and his observation proved true for me.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Rivets, Rivets, Rivets PSU1981 General Repair Forum 3 07-17-2018 12:02 PM
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 12:53 PM
Popping Rivets Inside my '07 Bambi iHayley Ribs, Skins & Rivets 9 10-06-2008 06:43 AM
'63 trotter popping interior ceiling rivets ChicknKathy General Interior Topics 13 05-01-2008 03:41 PM
Popping Interior Rivets in Maine!! 65Toaster On The Road... 6 06-16-2007 03:41 PM
