Old 05-19-2022, 05:07 AM   #1
Pakman31
2021 27' International
River Vale , New Jersey
Rivet question - no hole in second sheet
Hi there,
I am trying to replace a popped rivet, but upon closer inspection, I noticed that there was no matching hole for the second sheet of Al behind the surface sheet of Al (see photos).
Should I drill a new hole? What happened, did the sheet metal shift? I noticed this after driving back from the dealer in January, so this happened diring one, short trip.
I wanted to get some feedback from the community, because this would be my first attempted rivet replacement, and I do not like the idea of recklessly drilling a hole.
Thank you!
Best,
Paul
ID:	416235   Click image for larger version
pakman31 is offline   Reply With Quote
Old 05-19-2022, 05:24 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
It's hard to see in the photo. How deep is the hole?
2019 Ford Expedition Platinum
Old 05-19-2022, 05:49 AM   #3
Silvr_Bullet's Avatar
2017 16' Sport
N/A , New York
Is there any movement there with light hand pressure? That could be a clue if there is movement.
Silvr_Bullet is offline   Reply With Quote
Old 05-19-2022, 06:06 AM   #4
Pakman31
Not really. I tried light hand pressure & no movement. I tried to see if one of the sheets moved and if I could realign, but couldn’t easily line up the holes. Don’t know where the other hole went to!
Old 05-19-2022, 06:08 AM   #5
Pakman31
The depth of the top hole is the depth (or thickness) of the sheet metal. Can’t find or line up the top sheet with the hole on the second sheet (the inner sheet in this case).
Old 05-19-2022, 06:49 AM   #6
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Where on the trailer is this?
Richard
11018
richard5933 is online now   Reply With Quote
Old 05-19-2022, 11:07 AM   #7
RJJ
RJJ's Avatar
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg , Florida
Have you sought advice from the Mothership?? I'd seek there next... 🤔
RJJ is offline   Reply With Quote
Old 05-19-2022, 11:12 AM   #8
1959 24' Tradewind
Twin Falls , Idaho
You should be able to pull that top piece out a little bit with a plastic spudger tool or small pointed object and then use a tooth pick to feel around through the hole and see if you can locate if there was one there to begin with.
If you can't locate a hole, then just drill it out and put a rivet in.
Regards,
Tony
Trons4u is offline   Reply With Quote
Old 05-19-2022, 01:03 PM   #9
1960 26' Overlander
Tipton , Iowa
Assumption #1. This is an interior panel. Neither panel should move, but sometimes there is a little slop when you push down on an interior panel...one will move and the other one will not. That is a clue that a rivet is needed. Assumption #2, this is a new, or at least a newish trailer. It looks to me like the hole was never drilled on the bottom sheet, so no rivet was ever there. I would hazzard a guess that there is no problem drilling one and putting a pop-rivet in that matches the other ones in the area. I have had to replace MANY interior pop rivets in the 40 years I have owned my '60...many many miles on that trailer, and it has a lighter weight frame that bends and flexes.
Scott S is offline   Reply With Quote
Old 05-19-2022, 02:40 PM   #10
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
If you do decide to drill be sure to use a stop block on the drill to keep it from self feeding right through both skins.
Old 05-19-2022, 03:07 PM   #11
1988 25' Excella
1987 32' Excella
Is that an interior rivet missing or an exterior? The hole looks "funny" like maybe it was a bucked rivet.
Old 05-19-2022, 04:03 PM   #12
geirws's Avatar
send a email with a picture to the dealer maybe they can help you
irwin
geirws is offline   Reply With Quote
Old 05-19-2022, 04:09 PM   #13
2017 20' Flying Cloud
Williamson County , Texas
...and also tape over the hole to protect the aluminum from the drill stop.
FWIW I have found a couple of interior rivets that did not capture 2 layers, and three in a row near the return vent opening that missed the adjacent panel edge so only went through one layer. I added three rivets spaced evenly between the non functional rivets and it looks fine.
Based on the spacing of the interior "pop" rivets they are not really doing anything to enhance structural strength, they simply hold the interior panels in place, and it is the exterior shell that does all the work.
GMC Canyon V6 Mallet Supercharger
Chevrolet K2500WT 454
SYC2Vette is offline   Reply With Quote
Old 05-19-2022, 06:43 PM   #14
Pakman31
Inside bedroom. Here is another photo.
Old 05-19-2022, 06:44 PM   #15
Pakman31
Will do. I’m sure the dealer doesn’t want me showing up for such a minor job.
Old 05-19-2022, 06:45 PM   #16
Pakman31
Interior. Here’s the hole next to a rivet in place.
Old 05-19-2022, 06:47 PM   #17
Pakman31
Correct on both assumptions. Inside panel and 2021 27FB. It really looks like a hole was never drilled, so I am going to double check with the dealer & then drill a hole, insert rivet and complete job. .
Old 05-19-2022, 07:09 PM   #18
2022 28' International
Mercer County , New Jersey
It looks like there was never a rivet there. Are you sure there was one there at some point?
It seems improbable but maybe the piece of aluminum with the hole was a "scrap" from something else, the hole was unnoticed by the assembler, and there was no intent to place a rivet there.
jeffb831 is offline   Reply With Quote
Old 05-20-2022, 04:13 AM   #19
2019 30' International
Pennsylvania , Pennsylvania
This was along the lines of my thinking. There was never supposed to be a rivet there?, simply a hole that was drilled, not needed, overlooked, etc.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is online now   Reply With Quote
Old 05-20-2022, 11:44 AM   #20
Pakman31
Question resolved:
Per the dealer, I am going to drill a 1/8" hole into the second sheet & insert the rivet. I will use tape & a drill stop to avoid damage.
Thanks all for the responses and ideas.
Rivet Question; new rivet in new hole? griffithj General Repair Forum 2 07-04-2021 08:39 PM
Wanted: Blue Ox 9-hole or 11-hole shank Runamuk13 Hitches, Couplers & Balls 1 12-15-2020 01:18 PM
To rivet or not to rivet? That is the question LavenderMoon Forum Admin, News and Member Account Info 3 03-24-2013 09:07 AM
Hole in sheet metal banana wrap area kcbwil Belly Pans & Banana Wraps 13 11-15-2010 01:50 PM
Alice falling down the rivet hole... fotochop Ribs, Skins & Rivets 5 12-09-2007 03:26 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
