Old 01-02-2019, 12:42 PM   #1
1970 25' Tradewind
Haslet , Texas
Rivet Question
I am about to replace all of the belly skin on my Airstream. Everything I have seen says Olympic Rivets but my question is do I need the ones with or without the washer (I assume it’s Neoprene) on it. I tried the Vintage Airstream site and they are sold out of most but they have the 3/16 with the washer. Thank you in advance.
jeremyrp is offline   Reply With Quote
Old 01-02-2019, 01:06 PM   #2
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Olympic rivets have small heads and would tear easily on the pan compared to the large flange rivets. Search on the internet if VTS is out, OODM has them for sale. Olympics could get very expensive with the amount you will need.
cole3444 is offline   Reply With Quote
Old 01-02-2019, 01:31 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums (or maybe, welcome to your first post)!
Olympics are not what you want. Nobody is going to be looking for, or expecting to see, a "bucked" head appearing rivet down there. The belly skin was originally put in place using conventional pop rivets, and there is no reason not to use the same. The one upgreade I would recommend, as described above, is to use the .622" large flange pop rivets as offered by VTS at the link below.
https://www.vintagetrailersupply.com...-p/vts-283.htm
good luck!
Old 01-02-2019, 01:37 PM   #4
1970 25' Tradewind
Haslet , Texas
Thanks. The more I read the more I thought the same thing. Appreciate the quick response.
Old 01-02-2019, 05:42 PM   #5
1971 31' Sovereign
1972 31' Sovereign
Check with albanycountyfasteners.com they have the 3/16 all aluminum large flange.
Old 01-02-2019, 06:10 PM   #6
AFTER TAXES's Avatar
1964 22' Safari
1993 25' Excella
Flagler Beach , Florida
hmmmmm
try fender washers, with small hole
AFTER TAXES is offline   Reply With Quote
Old 01-03-2019, 07:14 AM   #7
1970 25' Tradewind
Haslet , Texas
I found some large flange rivets from Grainger for cheap.
Old 01-03-2019, 09:30 AM   #8
Belegedhel's Avatar
Houston , Texas
Make sure they have an aluminum mandrel, not steel.
Old 01-03-2019, 10:35 AM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Fender washers are galvanized steel. You will need a non metallic spacer between the washer and belly pan.
Otherwise the galvanic action will create a bigger hole in the belly pan.
I used FIP (fiberglass impregnated plastic) .
Not sure the name is right but it's the stuff one would use for a shower surround.
I would think that any plastic could be used.
I used a hole saw to make the spacers slightly larger than the fender washers.
Used 3/16" aluminum pop rivets.
Old 01-03-2019, 03:57 PM   #10
pjshier's Avatar
2017 27' International
Wasilla , Alaska
Nylon washers
I've used nylon washers between steel-variety fasteners and aluminum with some success. I also put the fasteners in a baggy with some CorrosionX or ACF-50 sprayed inside, and pull them from the baggy as needed. Because I am like that. I suppose it wouldn't hurt to fog the interior of the aluminum panel with same, if you are in a humid environment.
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 01-04-2019, 09:53 AM   #11
1970 25' Tradewind
Haslet , Texas
I did buy the aluminum mandrel ones. I’ve seen it when you mix metals before. Not fun to do all that work only to have it rot away and have to redo it.
To rivet or not to rivet? That is the question LavenderMoon Forum Admin, News and Member Account Info 3 03-24-2013 10:07 AM
Rivet on rivet repair Darkspeed Ribs, Skins & Rivets 2 08-19-2011 05:46 PM
What to rivet, and where to rivet it? DanielB Ribs, Skins & Rivets 5 04-27-2011 10:06 PM
I've got a rivet, I've got a rivet! wannastream Our Community 9 03-17-2007 09:27 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 05:41 AM
