04-23-2017, 07:23 AM
2020 30' Classic
2015 25' Flying Cloud
Blue Ridge
, Georgia
Right rear end cap dent
Bumped corner of house while backing up. Dent in right upper rear roof end panel. Any recommendations on where to have it repaired. Live in Blue Ridge, GA. ?
04-23-2017, 07:28 AM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Pics? Did you try suction cup?
04-23-2017, 09:06 AM
2020 30' Classic
Blue Ridge
, Georgia
Have not but thats a good idea. Just happened yesterday and visiting folks down in Florida. Thanks
04-25-2017, 03:54 PM
2020 30' Classic
Blue Ridge
, Georgia
dent photo 25'FC rear
Any suggestions?
04-25-2017, 03:56 PM
2007 22' International CCD
Corona
Also consider the small wheelbarrow inner tube, a piece of plywood, and a shop vacuum trick. Search the forum for details...
This can suck out bigger dents...sometimes.
04-26-2017, 01:35 PM
1965 17' Caravel
ALACHUA
Call JD SANDERS RV CENTER IN ALACHUA, FL. 800-541-6439
04-26-2017, 04:41 PM
2016 26U FC + 2011 LX570
2016 26' Flying Cloud
Houston
You can also remove the speaker from inside, below the rear locker and reach upward to access the back of the dent. Using some patience you can carefully press it out. Don't use any sharp cornered tool just soft touch and gentle pressing. You will be contacting the insulation, so wear gloves. Take your time - press a little at a time and go out often to check your progress. Don't ask me how I know this...
05-02-2017, 05:46 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
I just backed into an eave and dented a rear upper corner and the upper center panel on my 23 FB. Sad. Anyway, I took pics and emailed to Jackson center. $2500 to replace both panels. That's going 'all the way' since I'm insured and just can't live with dents on my 2014 trailer. Removing dents on the curved aluminum is tough, and removing the crease on the center panel (mine is creased from the roof facia that I hit) is all but impossible.
05-04-2017, 08:47 AM
1987 32' Excella
Nepean
, Ontario
JC now sells wireless backup cameras for trailers. I had one installed.
https://www.airstream.com/blog/how-t...tream-classic/
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
05-04-2017, 08:49 AM
Oswego
Gosh, that's $900 less than JC did my two panel repair for in 2011! Mine was insurance as well.
-Rich-
05-04-2017, 01:46 PM
The Aluminum Tent 3
Park City
, Utah
UPDATE: The initial quote was incorrect! They neglected to total up the labor for both panels, so with the additional 10 hours, my quote went from $2500 to $3900. Labor for the upper rear panels is 10 hours each at $129 per hour.
05-04-2017, 01:47 PM
The Aluminum Tent 3
Park City
, Utah
See my update on last post. There was a mistake, it's actually $3900 for the two upper rear panels.
05-04-2017, 01:49 PM
Oswego
That sounds more correct. Mine was $3400 in 2011.
-Rich-
