Austin
Pics might help but try removing the screws and carefully pull the Shur Flo out. This might/should expose the nut that holds the water line. Unscrew and reverse procedure lining the new one up with mounting holes.
I’ve replaced two but both on Classics with compartment hatch access.
If I’m wrong somebody will let me know.
Gary
