Originally Posted by sheriff1
There is a screw or screws thru the hose into the plastic vent. Remove the screws and the hose pulls right off. Also you might try releasing the hinges on the door and just set it aside.
Thanks. I had released the hinges, but the hose was still restricting my access. We just spent 3 nights at the Cades Cove Campground in The Great Smoky Mountains NP with no hookups, and the water pump started acting up where most of the time it would keep running at a slow idle. I had cleared all the air from the water lines, and I couldn't find any leaks. Sometimes it would stop when the faucet, toilet or shower was shutoff, but most of the time it would not.
I just made a minor adjustment on the by-pass adjustment screw and now it is (so far) always shutting off. I will monitor it for a while before trying anything else.
