Old 10-21-2016, 11:47 AM   #1
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Remove / Reset Fridge Vent - 2008 airstream
Long story short I need to drill out the rivets, remove my fridge vent to mess with some solar wiring.
My question is regarding resetting the existing vent. I have a little rivet gun and an assortment of rivets to mechanically fasten it back.
But with regards to sealants...
Q: Should I use a bead of Silkaflex between the vent mountain surface and the roof, then use some dicor over the top to seal the rivets from above? Or just use dicor throughout?
Thanks!
wulfraat is offline   Reply With Quote
Old 10-21-2016, 01:55 PM   #2
wulfraat's Avatar
Called airstream they said use adseal to form a gasket between the fridge vent cover flange and the roof.
I think I'll do that then go over the top with dicor perhaps for redundancy.
Old 10-22-2016, 12:03 PM   #3
wulfraat's Avatar
Connected with Lewster. Adseal sucks, apparently, I'm back to using Sikaflex per my original plan
Old 10-22-2016, 06:55 PM   #4
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
Sikaflex 221 all the way!
Kemblkr is offline   Reply With Quote
Return Vent - How to remove vent cover & Clean PSU1981 General Repair Forum 1 11-14-2015 09:17 AM
New Fridge, Old Fridge Vent TMT Refrigerators 0 10-17-2015 08:23 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 10:33 PM
Do you reset the brake controller for wet weather? richinny Brakes & Brake Controllers 4 06-12-2009 05:49 PM
Electrical Newbie with circuit breaker that won't reset...help please! Kerina Electrical - Systems, Generators, Batteries & Solar 13 05-04-2008 10:18 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
