Old 10-25-2021, 07:33 AM   #1
2018 22' Sport
Havertown , Pennsylvania
Refrigerator not cooling on Propane
Hi all!
We have a 2018 Bambi 22FB with typical factory installed Dometic fridge unit. Recently finding that temp stays nice and low when plugged into shore power but not when running on propane. Any ideas on where the problem lies?
iainmcc is offline   Reply With Quote
Old 10-25-2021, 08:53 AM   #2
"Cloudsplitter"
Ck the burner flame, should be nice and blue.
I clean the gas orifice yearly with a toothdbrush & Brakleen.
Make sure the flue is clear of 'bug junk' and the spiral baffle is centered properly in the tube.
3:31 in the vid for WTH is a flue baffle?
Old 10-25-2021, 09:41 AM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
You need a manometer to check the gas pressure. Fortunately, my trailer came with one plumbed in the gas line before the fridge. Checking gas pressure and adjusting the regulator for me is easy. I have had a poor cooling fridge in the past. I had a good flame, but gas pressure was low. Adjusting the regulator fixed the problem.
CRH is offline   Reply With Quote
Old 10-25-2021, 11:37 AM   #4
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Robert is on the right track. The orifice on the gas flame is the usual culprit. The tiniest spider, or fleck of dirt, or bug wing can cause the thing to operate incorrectly. The flame will be anemic, and the fridge will not cool right. Check this before you dig into anything deeper.
Lynn
ACI Big Red Number 21043
Old 10-25-2021, 11:51 AM   #5
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
it needs to be level also
waninae39 is offline   Reply With Quote
Old 10-26-2021, 09:56 AM   #6
2018 30' Classic
2018 33' Classic
Weatherford , Texas
Reset all of the circuit breakers; more than likely the GFCI breaker tripped, the flame needs 12v power to ignite the flame
smmckean is offline   Reply With Quote
Old 10-26-2021, 10:01 AM   #7
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
GFCI breaker is on the 120vac circuit(s) and should not have anything to do with 12vdc power.
Richard
11018
richard5933 is offline   Reply With Quote
Old 10-26-2021, 10:24 AM   #8
2019 30' Classic
New Milford , Pennsylvania
had the same problem. There are two, yes two, fuses on the back of the refrigerator. One is under a cardboard cover. I replaced both as one was blown and all worked.
AKmtnpilot is offline   Reply With Quote
Old 10-26-2021, 10:58 AM   #9
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
Following!
Old 11-01-2021, 10:12 AM   #10
2018 22' Sport
Thanks all! Problem resolved with some compressed air blown around the burner and burner box removed. All set
Solved: Dometic refrigerator not cooling on Propane Losman LP Gas, Piping, Tanks & Regulators 2 07-06-2020 09:56 AM
Dometic Refrigerator NOT COOLING sufficiently ctimberlake Refrigerators 3 09-15-2018 01:58 PM
Help! Domestic refrigerator not cooling. NWRVR Refrigerators 15 09-18-2016 11:07 PM
Refrigerator not cooling jimpappy Refrigerators 2 06-21-2012 08:54 PM
Refrigerator gurgling, not cooling Pacerized Refrigerators 7 04-21-2010 07:54 PM
