Old 03-01-2020, 10:28 AM   #1
tracys66
2015 25' Flying Cloud
Mandan , North Dakota
Refrigerator cooling fan noise
Does anyone have any quick fix remedies for quieting down the fan vibration noise from the cooling fan behind the refrigerator? It drives me crazy at night!
tracys66 is offline   Reply With Quote
Old 03-01-2020, 04:55 PM   #2
2023 27' Flying Cloud
Byron Center , Michigan
Our dealer installed a separate switch so we can turn it off at night. Our fan has a high pitched whine. Airstream is aware of the problem, as it was their recommended fix.
2travelers is offline   Reply With Quote
Old 03-01-2020, 05:00 PM   #3
Ray Eklund's Avatar
2019 27' International
2014 25' International
Oregon Buttes , Wyoming
Go to the Forum: Interior Restoration
Then to: Refrigerators
An excellent thread is being... kicked around and abused.
You can sell your current trailer and get one using the ceiling vent. Was one option.
Other options were not as extreme, but not a permanent cure, although decent improvements. Made less noise for more costs and you will still go crazy. I did the same mistake of having a Dometic with fans with TWO Airstreams. This last Airstream... NO Fan.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 03-01-2020, 06:04 PM   #4
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
If you can readily access the fan to the rear of the frig compartment, remove the mounting screws and insert a rubber washer with a metal washer on either side of the fan bracket. Once that is done use a locking nut to secure the screw. Good luck!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 03-01-2020, 07:12 PM   #5
2019 25' International
Providence , Senior Electrical Engineer
I did it one better......check out my thread here:
https://www.airforums.com/forums/f37...ge-196252.html
kittmaster is offline   Reply With Quote
Old 03-02-2020, 11:32 AM   #6
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
It drove me crazy too.
I removed it and replaced it with three quieter fans. I know am not suppose to post from other links, but I am not able to download pictures.
Here is the link to see what I did.
https://www.facebook.com/media/set/?...1572196&type=3
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 03-02-2020, 01:26 PM   #7
2021 25' Globetrotter
Poulsbo , Washington
Same issue and easy fix
I had the same issue when we picked up our 2017 FC 25RTB. That whine drove us nuts at night! I found the solution right here on the forum and it worked great. Basically, I opened the outside vent cover and detached the fan and suspended it off the bracket. Easy - just center and attach the fan using zip ties and some thin bungie cord to the 4 corners of the inside opening so it floats. The whine was the fan vibrating against the metal holding bracket and that was the whole problem. Now with the floating fan, the refrigerator is basically silent and even works more efficiently. It looks strange, but who cares? Or - just insulate the fan itself somehow from the holding bracket - metal on metal is bad. Get creative!
Check the threads for more information. I will subscribe to this link and send a photo if you are still looking after a few days.
2017 FC RTB
2019 F150 Platinum
dford77 is offline   Reply With Quote
Old 03-02-2020, 01:33 PM   #8
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
we use two quiet Muffin fans from an old computer.
they dont have to run very fast , just enough to move air.
an easy way to slow them down is to run them in series, thus each fan only sees 6v, vs 12v in parallel
waninae39 is offline   Reply With Quote
Old 03-02-2020, 09:48 PM   #9
MK1EO1
hddeering's Avatar
2020 28' Flying Cloud
Alamogordo , New Mexico
Did the same as above, rubber mounted the fan. worked well.
hddeering is offline   Reply With Quote
Noisy Refrigerator Cooling Fan short stuff Refrigerators 54 04-26-2021 11:35 PM
Refrigerator Cooling Fan Viggen General Appliance Topics 1 09-16-2019 05:49 PM
Cooling Fan - Refrigerator rkoepsell Electronics & Connectivity 20 09-02-2014 02:54 PM
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 12:18 PM
Dometic cooling fan noise dlb435 Refrigerators 10 06-24-2009 08:48 AM
