Old 08-10-2020, 11:45 AM   #1
Jochen & Christina
1965 24' Tradewind
Longmont , Colorado
rear end underside damage to 1965 Airstream Tradewind
Hi guys, we took our 1965 Tradewind across a pass in the Rockies this week. Unexpectedly the road became unpaved with some huge potholes. By the time I pulled into our side I noticed some pretty significant undercarriage and interior compartment damage in the back. It looks like one of the larger potholes really did a number on it and the entire bottom pan almost fell out, black water tank and all. Even the battery which was sitting on top of it busted its(rusty) metal railings and dropped down.
Because this is a new reno project I am not totally gutted - I had to get in there for a number of reasons - water heater needs replacing, I'm planning on getting a tank less one, the inverter is old and needs replacing, the plumbing has several leaks and needs a complete overhaul, the wood floor over the rear pan was mostly rotted and the box itself rusted. So this may be the chance to do it all at once
Have any of you had this happen? Any tips, tricks on how to a) secure it for the way home, and b) go about a repair for that?
This is my first Airstream so any pointers would be hugely appreciated!
Thanks so much!
ID:	375420   Click image for larger version
ID:	375422   Click image for larger version
Jochen & Christina
Longmont, CO
1965 Airstream Tradewind 24'
2019 Toyota Tundra
JochenML is offline   Reply With Quote
Old 08-12-2020, 10:35 PM   #2
VetteGuy's Avatar
1966 17' Caravel
Greenville , South Carolina
It happened to me last year my bottom belly pan pulled off when it was hit by a ladder that flip out of my trailer. My belly pan was hanging down very significantly I end up putting some self tapping screws into the aluminum sheet to the frame to secure it.
VetteGuy is offline   Reply With Quote
subfloor out, rear end damage Pams72 Repairing/Replacing Floor &/or Frame 2 03-23-2013 07:10 PM
Underside of 65 Safari? reddoor Belly Pans & Banana Wraps 0 04-21-2011 09:12 AM
Underside issue ramseyny 2000 - 2004 Safari 2 07-28-2010 08:33 PM
charred underside of refrigerator counter? barts Refrigerators 7 02-18-2010 08:59 PM
Underside damage truck tire tread - 2004 Classic gklott 2001 - 2005 Classic 1 06-11-2004 08:15 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
