Originally Posted by BKHall
Will this amount of water in that space hurt/damage anything in there?
Probably not. That's not enough to even make a puddle.
To toss out a couple of potential modifications to your rear storage compartment that make water less of an issue…
Some people I know have improved drainage of their rear storage compartment by drilling additional strategically placed drain holes. But that can backfire, too, because anyplace that lets water drain out will also let water in that is thrown up by the tires from a wet road surface. So if you add drainage, don't go overboard.
At least one person I know put down a layer of Dri-Dek (
https://www.dri-dek.com/) in their rear compartment so that anything left in the compartment doesn't lie directly in puddled water. You do lose some usable height in the compartment due to the thickness of the Dri-Dek, so it might cause problems if you store slinkies back there.
