Old 09-25-2022, 02:49 PM   #1
Revery's Avatar
2014 23' Flying Cloud
2015 28' Flying Cloud
Laguna Niguel , California
Propane Detector replacement no power
My 2015 Flying Cloud was asking for a new propane detector, original Atwood not available so local RV supplier sold me RVCOLP-2 CO / Propane Alarm. Box stated to be replacement for Atwood. Removed old and hooked up new but now there is no power coming to the alarm in order to test it. Checked wires for propoer connection and fuses all seems good. Anybody encounter a similar situation and know problem?
Revery is offline   Reply With Quote
Old 09-25-2022, 07:15 PM   #2
1988 32' Excella
Robbinsville , New Jersey
Someone else had that problem, issue was an inline fuse that will normally blow when you hookup a new propane detector without disconnecting all power first.
Old 09-25-2022, 09:35 PM   #3
2017 28' International
Jim Falls , Wisconsin
Yep. You must take out the fuse BEFORE installing new detector. It is only a 1 AMP fuse. Doesn’t take much to blow it. Mine was a pain to get to. My wife was able to get to it. I was just too big. Yours may be in a better location.
Daquenzer is offline   Reply With Quote
Old 09-27-2022, 07:36 PM   #4
Revery's Avatar
Yep! learned the hard way, my 28fc has the lounge in the front so the fuse was located behind and under the fixed frame of the couch (nice engineering). Since the opening is only about 10" tall and I weigh 215 lbs it was not easy exhaling and hold it while I crammed myself under the frame. But with prayer and persistence I was able to reach it and replace the fuse. Ace'd it on about the 5th trip under there. Next time I'll cut all the power first. Thanks folks hope this is helpful for the next guy that has to replace the propane alarm.
Old 09-27-2022, 07:43 PM   #5
Thatís where mine was located, only I couldnít squeeze in there. Felt like sending a nasty letter to Airstream about their crappy engineering. Next time I am going to disconnect the battery. Then I donít have to deal with the crazy fuse.
No Power to Propane Detector Ljsydney LP Gas, Piping, Tanks & Regulators 2 08-11-2020 06:46 PM
No power to propane detector tkowalyk LP Gas, Piping, Tanks & Regulators 13 09-10-2019 10:35 PM
No power to propane detector kebrita LP Gas, Piping, Tanks & Regulators 3 08-01-2019 09:32 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 09:56 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
