05-16-2022, 10:03 AM
Portland
, Oregon
Portable Air Compressor?
Do you travel with a portable air compressor?
If so, any recommendation?
Thank you.
Cheers,
Bryan
05-16-2022, 10:09 AM
Futurist
2021 27' Flying Cloud
Madison
, Wisconsin
We have a Dewalt 20V Max compressor and love it.
(I have purchased way too many different compressors/inflators over the years, and this is the first one I can unreservedly recommend.)
05-16-2022, 10:19 AM
2021 22' Caravel
Bozeman
, Montana
I wouldn't travel without a portable air compressor. Many gas stations' air compressors are impossible to access with a trailer. I have a Viair and am very pleased with it. https://www.technorv.com/viair-air-compressors/
05-16-2022, 10:44 AM
2008 22' Sport
Spicewood (W of Austin)
Yes! And you won’t believe the hard duty this cheap little hot-dog compressor is forced to endure.
FIrstly,…it’s a Harbor Freight 3 gallon “Hot Dog” which runs on 110 volts and creates 110 psi of pressure. I paid $39 for it on sale. It has not failed in 9 years despite the fact it’s contained inside an unventilated compartment.
It lives in the left RAM BOX of my pickup truck. It’s directly connected to a small 400 watt 120 volt inverter I paid $5 from Pep Boys (normally $25 on sale but came with a $20 rebate coupon.)
It was installed to power my TRAINHORNS instead of the $600 compressor the TrainHorn people specified. Yes, it does the job quite well and never runs out of air in that service. I routed air from it to the horns using plastic air-brake-line for 18-wheelers. It’s connected via a “Milton” quick-connector.
I use it to inflate swim-rafts, to blow dust/dirt/etc on small work-tasks, and tires of all sizes. I keep a 25’ coiled air hose also with a quick-connector in the Ram Box with it. I can open the lid, disconnect the TrainHorns and connect the hose for whatever other job I might want. (Note: Topping-off air in the Airstream or truck is a simple, quick job….but a large truck tire which is completely deflated will take about ten minutes or so. The first discharge of the tank will only result in about 15 psi of air in the tire due to the large volume/capacity of the tire. About 3-5 mins of the little compressor will top-off the tank, which can then finish off the tire refill.)
So, while it’s not a high-capacity compressor…it is a really affordable and helpful tool that fits inside a Ram Box where it’s out of the way and not likely to be stolen….but it will require the availability of an inverter…which by the way…my wife uses with an instant pot or a crock-pot while we’re travelling with the airstream to cook pot roast, etc on the back floorboard while driving down the highways. (I mounted the inverter beneath the drivers seat so it’s readily accessible inside the truck, and ran an extension from one of the two outlets to the Ram Box for the compressor.)
05-16-2022, 10:48 AM
2008 27' Classic FB
Jackson
, New Jersey
Thank you for asking this question. It is a purchase I am currently considering.
05-16-2022, 11:18 AM
2018 25' Flying Cloud
Smyrna
, Georgia
Viair 400P automatic
05-16-2022, 01:11 PM
2009 25' FB International
2018 27' Globetrotter
Hanover
, Pennsylvania
This is what I now have. I had a Viair and this is much easier to use. This is the perfect size with plenty of power and capacity for my 2500 tires as well as the AS tires.
05-16-2022, 02:04 PM
2013 25' FB Flying Cloud
Tallahassee
Viair 300rvs, is the way to go!
Find it on Technorv
05-16-2022, 02:08 PM
2020 16' Basecamp
Louisville
, Kentucky
Viair 400p
05-16-2022, 02:17 PM
2020 23' International
Evergreen
I’ve got a Vlair unit also that is 12V powered. I use it for tires.
I’ve carried a 6-gallon pancake compressor in my truck bed when camping in transitional times between fall and winter when a quick de-winterization might be necessary, but this isn’t something that I typically do.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Sierra Denali 1500
Airstream Club International #2805
05-16-2022, 02:28 PM
Futurist
Madison
, Wisconsin
Yup. Used to have a Viair too (400P, I think), and while it was definitely a sturdy unit, the DeWalt is built just as well and way more convenient to use.
05-16-2022, 03:07 PM
Evergreen
What makes the DeWalt unit more convenient? I’m just curious. My Vlair just hooks up to the battery, I screw the nozzle on the valve stem, and turn it on. It’s not especially inconvenient.
Dennis
05-16-2022, 03:19 PM
Tampa
Yep.
I must admit the coil hose drove me crazy with tangles, so I made a 30' regular air hose with female couplers on both ends. (For some reason, Viair puts a male coupler on the compressor.)
The fittings are 'industrial' or 'D' standard, and it'd recommend the 'automatic' coupler, which you simply push on and it latches.
05-16-2022, 03:39 PM
2021 20' Caravel
Plaistow
, New Hampshire
Although we're a Dewalt house our compressor is a Viair 88 P(12 V). Great compressor, battery clips to go direct.
Learning and enjoying as we go !
05-16-2022, 03:43 PM
2019 25' Flying Cloud
Houston
We do not have one. I am kind of curious what those that carry compressors use them for apart from inflatable toys. I get that they would be handy for full timing, but we fall into the occasional use category. I always check tires before we go. If I had tire punctured, I would change the tire. Just wondering if I am missing something.
05-16-2022, 03:46 PM
2021 20' Caravel
Plaistow
, New Hampshire
Tow vehicle and dual axle trailer plus spares equals 10 tires. We have a single axle but that's enough reason for me. Have used it.
05-16-2022, 03:51 PM
Evergreen
I store mine in my trailer’s outside storage compartment. I frequently use it at the storage facility before a trip. I don’t use it as often on the road, but I have before.
Dennis
05-16-2022, 05:56 PM
Oswego
Although my truck is gas, and has only one battery, it has two battery trays. My compressor is stored under hood on the empty tray.
Sent from my SM-G950U using Airstream Forums mobile app
-Rich-
05-16-2022, 06:28 PM
1994 25' Excella
Waukesha
, Wisconsin
Another vote for Viair.
Richard
11018
