Old 08-02-2021, 05:42 PM   #1
1976 27' Overlander
Milwaukie , Oregon
Pointers on replacing AC / vents
Greetings, Airstreamers. Long time no post. Looking to do some work on the lifelong restoration of my 76 Overlander. Interior is stripped and looking to replace the old Dometic Quick Cool AC with a Penguin II. Also looking to replace the existing vents (I think stock with some crappy fiberglass added for ghetto sunroof?) with Maxxfans. I'm curious if anyone can provide pointers on things I'll need for this replacement.
Of note, I managed to find a Penguin II on the used market, but it was actually new in box (still had protective film) but did not include any sort of accessories. It's essentially the air conditioner (with the foam attached on the bottoms), and the air distribution box / metal plate with switches.
The other thing of note is I plan on doing white paint on the top down the line (I've read a few threads on this and haven't decided on a product but wonder if that will be necessary to do before or after, or irrelevant).
I'm guessing I need to get up there, remove the AC and vents, scrape off the bulk of the crud / old sealant, use some type of degreaser (?), strip the clear coat while I'm up there, and install.
Will I need to use any type of sealant on the new AC, or does the compression against the foam provide enough of a seal? Anything I need to buy from Dometic in advance? The interior is stripped and I plan to buy heat element / strip and tubing for condensation drainage.
Thank you for providing any info! Providing photos to show what kind of mess I'm looking at.
ID:	400926   Click image for larger version
JoleneAS is offline   Reply With Quote
Old 08-06-2021, 09:44 AM   #2
1976 27' Overlander
Milwaukie , Oregon
Hey guys, sorry to bump my own thread. My mom is coming out to help watch my kiddos while I get the old air conditioner and vents removed and put on a new air conditioner before the end of the dry season here in the Pacific NW.
What's the best method of removing the old sealant gunk? Simple Green, Goo Gone, etc? Anyone have issues installing their AC directly to the rounded surface of the Airstream roof?
Thanks for any thoughts and sorry to be a pain.
Old 08-09-2021, 11:31 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
When I replaced/resealed the vents on my AS roof, I used an oscillating tool with a scraper to remove the old sealant.
CRH is offline   Reply With Quote
Air conditioning vents screens not the ducted vents. We are trying to locate them and cegardner General Interior Topics 3 04-25-2021 07:06 PM
Changing roof vents to fan vents stgerdonly Roof Vents, Skylights & Fans 1 12-28-2014 05:42 PM
Backing - Method, Tricks, Pointers??? kudzu Community Polls 14 05-30-2006 07:36 PM
need a few pointers with purchase of airstream....new to forum! a-wanabbee Member Introductions 5 03-19-2006 08:27 PM
Pointers for Trip to Mammoth, CA Safari-Rick On The Road... 7 07-19-2005 04:16 PM
