Get a piece of insulated copper wire 12 or 14 guage) and push it down the drain tube. You might try a few drops of dish soap on the end for lubrication. Could be a dead insect, random road debris, or a kink in the hose
Also try sucking or blowing air through the tube from the bottom. Use a tire inflater pump or a wet-dry vac. Partly open will work just fine.
Those damn drain hoses can be hard to access, although a long hard look at where the hose comes out will generally point you in a good way. Commonly the drain hose runs through the refrigerator wall or the closet wall. If you replace or repair the fridge, fix the drip hose too!
